Spark Plug query
02 Aug 2021 08:56 - 02 Aug 2021 08:58 #24963 by kevinross
Spark Plug query was created by kevinross
while investigation my Saito FG30 (four stroke) , i noticed dirt on the spark plug ceramic insulator which appears to be combustion leakage thru the plug. However the rubber seal in the cap has prevented this contaminating the HT contact.
Q Ive never noticed spark plug leakage before on a 2 stroke so wondered if this is normal ?
Last edit: 02 Aug 2021 08:58 by kevinross.
02 Aug 2021 16:34 #24970 by Phil Ford
Replied by Phil Ford on topic Spark Plug query
I think that I usually saw this on engines that have been overheated, thrashed or a lean burn at some time or other. High heat can create minute cracks in the ceramic insulator. This was with cars though but probably quite relevant
Time to create page: 0.539 seconds
