Fuel Dots
  • AlanF
12 Jul 2014 23:46 - 12 Jul 2014 23:50 #2395 by AlanF
Fuel Dots was created by AlanF
I need one to feed my OS GT 22 - It would seem one could spend anything from a quid for a ming yang cheapo Chinese jobber to 20-30 quid for some multi bolt ally bling , but has anyone got a recommendation for something cheapish that works but isn't a wood screw and a cable tie!
Edit - I'm running a 3 line system so don't need carb shut off.
Last edit: 12 Jul 2014 23:50 by AlanF.
  • Stuartmck
13 Jul 2014 09:27 #2401 by Stuartmck
Replied by Stuartmck on topic Fuel Dots
Locally, X-Tech can be purchased from Probuild for £5.50 a pair. Would cover your needs. On most of my I.C. models I use similar without any problems.
Stuart
13 Jul 2014 12:12 #2406 by kevinross
Replied by kevinross on topic Fuel Dots
You can also use the Radio Active GA2039 FUEL PROBE - Ive used them successfully for years with petrol and glow fuel especially on
3/32" Tygon tube and available at proper Yorkshire prices !!
www.radioactivemfg.com/Catalogue/p13.htm
13 Jul 2014 14:30 #2408 by JonTappin
Replied by JonTappin on topic Fuel Dots
www.hobbyplastic.co.uk/index.php?main_pa...c1a476ebb7de2ae1b9ee
Don't know what your 'cheap' limit is Alan, but the Secraft fuel dots are simple and effective and not too expensive, also a nice bit of bling!
  • AlanF
13 Jul 2014 14:52 #2409 by AlanF
Replied by AlanF on topic Fuel Dots
Thanks for replies chaps. X-Tech seem to be critical on fuel tube size I'd need to check that they work with Tygon, The price of the Radio Active items definitely falls within my definition of cheap! and as it works with Tygon it looks a winner - but 12 quid for a bit of bling, I could start spending the kids inheritance :)
Time to create page: 0.300 seconds
