Inconsistent Tickover
21 Sep 2015 17:58 #6090 by Chris73
Inconsistent Tickover was created by Chris73
Help needed please.
The last time I flew Chloe's Edge I noticed that I had to trim down a lot more than usual to get the idle low enough to land, on the ground the idle was all over the place. I stripped it down tonight and the servo seems to centre ok and all of the linkages are tight. There was a bolt missing from the manifold and the remaining bolt was loose, could this have caused the problem????
  • FrankRobinson
21 Sep 2015 18:18 #6093 by FrankRobinson
Replied by FrankRobinson on topic Inconsistent Tickover
Yes Chris, the back pressure in the exhaust would be all over the place the flanges could have been covering the ports with the viberation. :(
21 Sep 2015 18:25 - 21 Sep 2015 18:26 #6096 by JonTappin
Replied by JonTappin on topic Inconsistent Tickover
If the manifold was loose enough to be blowing past the gasket, which it probably was, then yes that will affect the idle, as you are losing exhaust back pressure.
Edit. Frank beat me to it :)
Last edit: 21 Sep 2015 18:26 by JonTappin.
21 Sep 2015 18:53 #6102 by Chris73
Replied by Chris73 on topic Inconsistent Tickover
Thanks guys, manifold is now tight so hopefully problem solved :)
21 Sep 2015 18:54 #6103 by AlanF
Replied by AlanF on topic Inconsistent Tickover
Check the exhaust port faces for signs of hammering. When this happened to me I had to lap the face of the exhaust to get a decent seal again. Luckily the engine exhaust face was ok. I now use nordlocks and gasket sealant around the exhaust screws and things have remained tight so far.
21 Sep 2015 21:28 #6112 by JRI
Replied by JRI on topic Inconsistent Tickover
IMHO - watch out for the carburettor arm butting up to the manifold/casting at tickover especially on DLE engines. Caught me out!
Time to create page: 0.414 seconds
