Joining stainless steel exhaust components
  • JRI
9 years 7 months ago #8156 by JRI
Thanks Kev, I may well take you up on that Kind offer. Hopefully learn from the master how to do it myself ;)
  • JRI
9 years 7 months ago #8157 by JRI
kevinross wrote: Ive dome a lot of SS exhaust work and always use this flux - it does what is says on the label
I recommend this company for your Silver Solder
www.cupalloys.co.uk/medium-temp-silver-solder/index.asp
I have an Oxy / Mapp gas facilities if you want me to solder it for you.
Hi Kev, which of the silver solder diameter rods do you recommend?
9 years 7 months ago #8160 by kevinross
Replied by kevinross on topic Joining stainless steel exhaust components
Most solders will work but your choice is based on your heat source. My oxy-mapp torch has unlimited heat but if you use a std propane torch the lowest melting temp solders are preferred but that means higher si content and carries a higher price
The smaller 1mm 650deg can be "ringed" around the flange. then it will run and fillet the join very well with plain Mapp gas.
ps - there is a small brazing hearth in "Franks stuff" if you're interested.
Time to create page: 0.226 seconds
