DIY? SAS Wildthing
12 Jan 2018 12:27 #15366 by Phil Ford
DIY? SAS Wildthing was created by Phil Ford
Can some kind member with a SAS Wildthing 46 take some measurements for me.
1. Width of wing root.
2. Length of fuselage from nose to leading edge of wing
3. Depth of fuselage from underside of wing at thickest point.
4. Width of fuselage at widest point
12 Jan 2018 14:06 #15368 by Chris73
Replied by Chris73 on topic DIY? SAS Wildthing
Just buy one you tight git !!!
Its a small family run business, copying their designs is how these small company's go bust
12 Jan 2018 15:09 #15369 by Phil Ford
Replied by Phil Ford on topic DIY? SAS Wildthing
Chris73 wrote: copying their designs
I am not copying their design thank you very much.;) All I wanted is their dims so I can compare them with MY design of a new Marley Fighter slope version
Maybe I should've titled the post better. Anyway my design will now stay secret until it flashes past your Wildthingy :whistle:
12 Jan 2018 15:26 - 12 Jan 2018 15:32 #15370 by JRI
Replied by JRI on topic DIY? SAS Wildthing
The Russians didn't want to copy the design of the Rolls Royce Nene engine either, they just wanted the dimensions to compare with their very own Klimov VK-1 ! And of course it was was just a coincidence that the Chinese WoPen WP-5 was rather similar too !!!
Last edit: 12 Jan 2018 15:32 by JRI.
12 Jan 2018 17:44 #15373 by AlanF
Replied by AlanF on topic DIY? SAS Wildthing
PhilF51 wrote: Can some kind member with a SAS Wildthing 46 take some measurements for me.
TBH Phil, I would make the fuselage dimensions fit the radio and batteries I was using, with the depth under the wing enough to give a decent grip for launching. Unless you use the same EPP as SAS I suspect you'll want different dimensions any way to balance it out. I can give you the wing root dimensions but it'll have to be in secret so no one will know - actually why not pick a root and tip section yourself and do your own thing entirely.
13 Jan 2018 10:45 #15378 by Phil Ford
I had not kept any workings out on paper or created a story giving dimensions on the web when I built the Marley Wing. But looking around at images I would estimate that the fuselage nose where the battery will likely be for balance is about 40% of the wing root. As you say depth can be judged by what is comfortable to hold to launch.
This time I will keep a record of the dimensions I used, if and when a successful outcome unfolds. Many have said that I am an ARF man. That may be true but creating something yourself, a custom unidentified flying object is quite exciting. You become to realise what the Wright Bros must have felt.:lol:
Before anyone steals my creation it is codenamed "WildCat" Already printed out the wing graphic.
13 Jan 2018 17:40 #15383 by 4Pedalsfly
Replied by 4Pedalsfly on topic DIY? SAS Wildthing
Chris73 wrote: Just buy one you tight git !!!
Chris - Not that tight - wait till he turns up with his E.D.F. " Valkeri" retracts n all.
13 Jan 2018 19:08 - 13 Jan 2018 19:09 #15386 by Phil Ford
I think it is spelt Valkyrie aka XB70, Colin. And it should not look like this Mach 3 monster. Oh, should be yellow in colour;)
Last edit: 13 Jan 2018 19:09 by Phil Ford.
14 Jan 2018 08:08 #15391 by Brian
Replied by Brian on topic DIY? SAS Wildthing
Your Valkyrie may be yellow, but I'm green with envy.
14 Jan 2018 09:16 #15396 by Phil Ford
Hang on a cotton pickin' minute! you have a nice green MX2 aerobat to zip around. ;)
Time to create page: 0.361 seconds
