'Stratus' built from an rcme plan in the 1970s?
  • Simon O
14 Dec 2019 14:44 - 14 Dec 2019 14:45 #21300 by Simon O
I acquired this machine recently. I have replaced all the servos etc with upto date items and made a wing spar from a piece of alloy bar. I'm now stuck when it comes to making the 4 piece wings secure, there's no obvious way of stopping them coming apart. Anyone have knowledge on how to fix them?
Simon O
Last edit: 14 Dec 2019 14:45 by Simon O. Reason: Attach pics
14 Dec 2019 15:29 #21301 by kevinross
Replied by kevinross on topic 'Stratus' built from an rcme plan in the 1970s?
I think its common practice to wrap clear tape or matching electrical tape across the joins.
PS this is how i used to fix full size aircraft but this is aviation grade sticky tape ! :blink: :blink: :blink:
  • Simon O
14 Dec 2019 17:12 #21302 by Simon O
In other words you used 'Gaffa Tape' Kevin!
14 Dec 2019 18:03 - 14 Dec 2019 18:04 #21303 by Phil Ford
Replied by Phil Ford on topic 'Stratus' built from an rcme plan in the 1970s?
3M Blenderm tape methinks. Will hang on well but can be peeled off fairly easily without puling the covering off with it. Blenderm has worked well for foamie hinges.
Mike may have an answer to your problem
Last edit: 14 Dec 2019 18:04 by Phil Ford.
14 Dec 2019 19:33 #21304 by MikeSeale
Replied by MikeSeale on topic 'Stratus' built from an rcme plan in the 1970s?
Put a wrap of uv resistant clear tape (sellotape crystal clear) on the wing/fuselage first. Then use electrical tape each time you fly. The clear tape will stop the covering from peeling off when you remove the electrical tape.
Blenderm will be ok too but is a lot more expensive.
