Wire Bending
26 Oct 2016 16:07 #10453 by Phil Ford
Wire Bending was created by Phil Ford
Is there anywhere local that supplies and bends 4 gauge (5.2mm) steel wire? I have spoken to SLEC regarding Chipmunk but they are extremely busy at present and cannot guarantee when Chris can make me up another set of gear.
I have got a new set for from the Pepsi to act as a pattern/template because the angles need to be spot on.
26 Oct 2016 20:48 #10456 by John Bannister
Replied by John Bannister on topic Wire Bending
Phi, Probuild say they have 7/32 piano wire on there website I can probably bend it for you, get two lengths.
27 Oct 2016 08:56 #10458 by Phil Ford
Replied by Phil Ford on topic Wire Bending
Thanks for the info John. 7/32 = 5.55 whereas the original 4 gauge = 5.189 (round it up to 5.2mm). The latter wire fits very neatly in the wing gear sockets already so really want to avoid drilling out a tiny bit more. However, 7/32 may be a fallback plan.
Tried bending this wire before in a vice - it doesn't work very well. Really need the proper bending tool for those sharp right angles too.
27 Oct 2016 15:24 #10460 by 4Pedalsfly
Replied by 4Pedalsfly on topic Wire Bending
Phil - Maybe worth putting an enquiry on the BMFA site, some scale types probably have
the kit for wire bending. Not sure at what point Wire becomes Rod.
27 Oct 2016 18:03 #10463 by Phil Ford
Have spoken again to SLEC and can confirm that the wire they use is 6mm. Why the first Guy I spoke to got 4 gauge from dunno?
27 Oct 2016 18:41 #10466 by DavidTappin
Replied by DavidTappin on topic Wire Bending
4 swg (Standard Wire Gauge) is 5.89mm diameter.
Maybe that's where the guy at SLEC got it from Phil!
27 Oct 2016 18:45 - 27 Oct 2016 18:46 #10467 by MikeSeale
Replied by MikeSeale on topic Wire Bending
4 SWG is 5.89mm, Phil
Spent too long typing and David beat me to it.
Last edit: 27 Oct 2016 18:46 by MikeSeale.
27 Oct 2016 18:46 #10469 by DavidTappin
4 minutes too late with that Mike!
27 Oct 2016 18:50 - 27 Oct 2016 18:50 #10470 by Phil Ford
Thanks Guys. I think I got confused earlier with diameters, I think I was looking at AWG instead of SWG. Now it is as clear as mud.
Last edit: 27 Oct 2016 18:50 by Phil Ford.
