Logic EC5 connectors
  • Simonosborne53
15 Jan 2017 09:25 #11544 by Simonosborne53
Logic EC5 connectors was created by Simonosborne53
: :( Having had no experience of these connectors, I'm baffled as to how you instal the metal connectors into the accompanying plastic housing they are designed to fit. Any guys.
Thank you.
15 Jan 2017 10:34 #11545 by Chris73
Replied by Chris73 on topic Logic EC5 connectors
if i remember correctly, you solder the connectors and then push them in from the top, until they lock in place
15 Jan 2017 10:45 #11547 by DaveBright
Replied by DaveBright on topic Logic EC5 connectors
The following user(s) said Thank You: Simonosborne53
  • Simonosborne53
15 Jan 2017 14:05 #11554 by Simonosborne53
Replied by Simonosborne53 on topic Logic EC5 connectors
Thanks Dave, all sorted
  • Stuartmck
15 Jan 2017 14:06 - 15 Jan 2017 14:07 #11555 by Stuartmck
Replied by Stuartmck on topic Logic EC5 connectors
A good fine screwdriver is an absolute necessity. Make sure that they are really locked home. Originally had trouble with EC3's that appeared locked, but weren't.
Stuart
Written before Simon's reply!
Last edit: 15 Jan 2017 14:07 by Stuartmck. Reason: Addition
15 Jan 2017 18:14 - 15 Jan 2017 18:17 #11559 by kevinross
Replied by kevinross on topic Logic EC5 connectors
While on the subject of soldering loose pins - I find the Hobbyking "Mr grippy jig" extremely useful and it doesn't sap the heat which metal pliers do in the you-tube clip.
Its currently in stock at the uk warehouse and qualifies for the < 200g postage
Last edit: 15 Jan 2017 18:17 by kevinross.
15 Jan 2017 21:41 #11564 by Chris001
Replied by Chris001 on topic Logic EC5 connectors
While on the subject of soldering connectors, what soldering irons, tips and wattage are your preferring?
I'm generally using a 25W Antex with a chisel tip and 60/40 solder. But sometimes feel it's taking a while to get the heat into something like a 5.5mm connector.
15 Jan 2017 21:52 #11565 by MikeSeale
Replied by MikeSeale on topic Logic EC5 connectors
I nearly posted a comment about soldering irons earlier when I saw the inappropriate tip being used in the video.
My 'go to' iron for connectors is a 75W with a 10mm chisel tip.
