Launch Pedal
7 years 9 months ago - 7 years 9 months ago #15089 by Phil Ford
Replied by Phil Ford on topic Launch Pedal
Did a test set up and made up lines today. I need to melt down the plastic a little bit more at the top end to save wing damage. And a "drag chute" ( a bit of rag) where the lines meet the bungee to slow and pull down the bungee after launch. Or is it really necessary?
Last edit: 7 years 9 months ago by Phil Ford.
7 years 9 months ago #15090 by kevinross
Replied by kevinross on topic Launch Pedal
DavidTappin wrote: Phil, while you're at it I think you will find that Kevin has also had some useful experience on the subject of prop rotation.
I thought the prop direction was fine - i just had the model back to front !!
