real flight 8
  • JacobWinfield12
01 Feb 2018 17:25 #15601 by JacobWinfield12
real flight 8 was created by JacobWinfield12
I have just got real flight x wireless interface and could not connect my dx8 to the sim does any one have any ideas why this could be.
01 Feb 2018 17:38 - 01 Feb 2018 17:40 #15602 by Phil Ford
Replied by Phil Ford on topic real flight 8
Do you mean the Real flight is not finding the DX8?
Or not connecting?
You need to tell us what you have done so far.
In the meantime, I am assuming you are running Windows 10 on a PC.
When you plug in the interface lead into a USB port did the system say found new USB device?
Last edit: 01 Feb 2018 17:40 by Phil Ford.
  • JacobWinfield12
01 Feb 2018 17:41 #15603 by JacobWinfield12
Replied by JacobWinfield12 on topic real flight 8
I do run windows 10 and I'm not sew about it being found on a new usb device but the interface flashis red then turns of and is no light.
01 Feb 2018 17:51 #15604 by Phil Ford
Follow this link from Real Flight. There are a number of reasons so you need to work through them gradually.
www.realflight.com/support/kb/article.php?q=01-1022
  • JacobWinfield12
01 Feb 2018 17:52 #15605 by JacobWinfield12
Hi Phil,
I am Jacob's dad.
What we have done is bought the wireless interface RF-X which Sussex Model Centre suggested. We have plugged it into the USB and attempted the binding process, but it did not work. The controller shows the orange light on which I believe means it is transmitting? On the wireless interface it has a red light which is flashing, if it successfully binds than it will go a solid red.
Any ideas?
KR's
Julian
01 Feb 2018 17:58 - 01 Feb 2018 18:11 #15606 by Phil Ford
Sorry, I should've read the post carefully. You are using a wireless interface ,not a hard wired lead. Not sure on this one but if the interface is transmitting then you need to go into the DX8 bind mode as if you were binding (pairing) a receiver.
Note: Interface is not compatible with version 6 or lower.
Oh, and ensure you are PPM mode on the Transmitter.
DX8 owners jump in here....
Edit: Have you selected from the Real flight menu Simulation (top left corner) and chose the transmitter you are using. That is a definitely a good start.
Last edit: 01 Feb 2018 18:11 by Phil Ford.
01 Feb 2018 19:49 #15608 by Chris001
Replied by Chris001 on topic real flight 8
I hesitate to jump in as I'm not familiar with the system, but if you only have the 'Realflight RF-X Wireless Interface' then it will not work with most radios:
"instantly ready to link up your SLT radio (Tactic)"... "Required for non SLT transmitters: P-TACJ2005 - Anylink2 - 2.4GHz Universal Radio Adapter"
The transmitting protocols between the two systems are different, to make the Spektrum work with it you apparently need the Anylink2 - 2.4GHz Universal Radio Adapter which I assume plugs into the trainer port on the back of the transmitter. This is another £38 www.sussex-model-centre.co.uk/anylink-2-2-4ghz-radio-adapter
I can't help thinking this is a lot of money for the ease of a wireless setup.
Please double check my conclusions I've got a cold and made more than my usual number of mistakes in the last couple of days.
01 Feb 2018 19:55 #15609 by MikeSeale
Replied by MikeSeale on topic real flight 8
If Chris is correct and you don't already have the Anylink adapter, I'd suggest getting a refund and buy a cable to join your DX8 to the PC. A wired connection is not a problem for a flight sim where you're not moving around much anyway. And wired could be preferable for the solid link and lower power consumption.
Time to create page: 0.301 seconds
