Multiplex Connector
30 Apr 2018 11:46 #16443 by Phil Ford
Multiplex Connector was created by Phil Ford
Trying to tidy up and make it easy to plug/unplug wing connections on my latest aquisition. Other than computer type connectors I was looking at Multiplex 6 way connectors. Do they fit well, in other words they are not likely to come loose in an IC powered plane. I know some of you use them in EP powered planes but was considering the vibration aspect.
eg: www.multiplex-rc.co.uk/m6-socket-248-p.asp
  • throttletothewall
  • Senior Member
  • Senior Member
30 Apr 2018 12:41 #16444 by throttletothewall
Replied by throttletothewall on topic Multiplex Connector
Phil,
They are pretty secure (quite tight fit usually) but if you want them to be ultra secure you can get clips to go over the socket part to help hold the plug and socket together. See the pics of the clips on my Pilatus PT6, I think I got the clips from Nexus Bob.
Peter
30 Apr 2018 13:08 #16445 by Chris73
Replied by Chris73 on topic Multiplex Connector
Hi Phil
I use them in all of my large planes and have not had any issues, like Peter has said, you can get a safety clip but I have never felt them need for them
30 Apr 2018 13:26 - 30 Apr 2018 13:34 #16446 by Phil Ford
Replied by Phil Ford on topic Multiplex Connector
Cheers Guys. although the type I am looking at are below and they are fairly small. I am sure I have seen Mike use these in a glider though. My aquisition is only a 60 size model.
6 pins gives me, 1 Common: 1 pin power: 2 pins L- Ail R - Ail: 1 pin Flap: 1 pins for retracts.
Last edit: 30 Apr 2018 13:34 by Phil Ford.
30 Apr 2018 14:44 #16447 by DaveBright
Replied by DaveBright on topic Multiplex Connector
Use Multiplex with no issue. Also like these a lot Molex
Time to create page: 0.286 seconds
