Tail Wheel Springs
7 years 1 week ago - 7 years 1 week ago #17920 by JRI
Replied by JRI on topic Tail Wheel Springs
Phil, please re-measure your wire diameter !!!
I don't believe it is as thin as you think, unless its on a micro-plane of some sort !
If it really is only 2 and a bit thou' diameter then I am surprised you can even see it!
Last edit: 7 years 1 week ago by JRI.
7 years 1 week ago #17921 by Phil Ford
Replied by Phil Ford on topic Tail Wheel Springs
Brain Fart I think. :huh: Take off a nought. Try Spring Wire gauge = 0.62mm
Met Kevin today and he came up with an alternative idea and gave me a couple of springs to have a play with. Springs are 25mm long, 6mm dia with loops at each end. Create links to tiller arm, etc, using heavy duty trace wire with a clevis at one end to adjust tension. The springs appear to have the same amount of tension as the originals. Will give it a go at least.
7 years 1 week ago #17922 by Chris73
Replied by Chris73 on topic Tail Wheel Springs
Have never tried it myself, but lots of people have thrown away the springs and are just using fuel tubing and cable ties
7 years 1 week ago - 7 years 1 week ago #17923 by Phil Ford
Well here is my trial of the earlier idea. Works perfectly! Although if we can get a supply of OEM copies of springs all the better. I think my original spring end probably snapped after a couple of bends when fitting it.
Maybe now I can get back to other maintenance jobs and the Phase 6.
Last edit: 7 years 1 week ago by Phil Ford.
Time to create page: 0.229 seconds
