Epoxy Glass Sheet
11 Mar 2019 16:35 #19039 by Phil Ford
Epoxy Glass Sheet was created by Phil Ford
A long time ago Pete C gave small amount of this stuff to make up dummy missiles, etc. Rolled easily, etc but seem to have lost it. :( I want make some LED gun ports and light surrounds.
On Hobbyplastic I found this. Would this be suitable? Epoxy Glass 1200 x 1000 x 0.2mm or go for 0.4mm?
11 Mar 2019 17:13 #19041 by kevinross
Replied by kevinross on topic Epoxy Glass Sheet
Not clear what you wish to achieve Phil but assume you want something shaped to a leading edge or front fuselage section in which case i would consider making a mould and ask John B to vac form something for you.
11 Mar 2019 18:44 #19043 by DaveBright
Replied by DaveBright on topic Epoxy Glass Sheet
I can also recommend John B’s vac forming skills. Phil, feel free to use some of that blue foam... when you’re done, can I have some of it back please! :-)
12 Mar 2019 09:37 - 13 Mar 2019 12:37 #19045 by Phil Ford
Replied by Phil Ford on topic Epoxy Glass Sheet
John B is already busy making wing tip lens for my Otter. ;)
Pete C gave some sheet epoxy which he used to make the missile/bomb bodies on some of his builds. It was as thin as paper and you could roll it up into a tube. you could make the fins too. all you needed then was a balsa nose cone.
I want to make up some tube to fit around some power LEDs. Had thought of carbon tube if I can find the right internal diameters but thought Epoxy sheet gives a lot more options.
Blue foam Dave. Will do.
Last edit: 13 Mar 2019 12:37 by Phil Ford.
12 Mar 2019 10:51 #19046 by Phil Ford
Here is some of the stuff I am working on. A power LED and driver is glued into the back of a headlight lens unit (22mm dia, 60 deg sideways by 30 deg down) really for scale cars but would make excellent landing lights. The smaller one is a Xenon effect lens (10 deg field) which is only 16mm dia. Cannot show you the output of the headlight as the camera would be blanked.
12 Mar 2019 15:00 - 12 Mar 2019 15:00 #19048 by kevinross
there is a model shop (trains etc) behind the quay is poole which sells a range of white PVC tubing which might work
Setchfields
4.0
(38) · Model shop
21-25 High St
01202 673300
Open ⋅ Closes 5PM
Last edit: 12 Mar 2019 15:00 by kevinross.
13 Mar 2019 10:33 #19049 by John Bannister
Replied by John Bannister on topic Epoxy Glass Sheet
Wrapped a bit of glass cloth round a piece of 22mm copper tube which I had sprayed with furniture polish and coated it with epoxy resin then wrapped it again with masking tape .
Problem getting it off this morning had to slit it.
Might try slitting tube so I can compress tube slightly or wrap the tube with selotape first and hope glue becomes slippy when heated so I can slide it off.
Any other ideas bearing in mind that fibre glass shrinks on curing
13 Mar 2019 10:52 #19051 by Phil Ford
Experimentation! I looked at various carbon tube on my travels in Net Land. One version is pultruded - where the cloth is wrapped around a mandrel in a linear fashion. Then you get roll-wrapped and woven.
Then I have just looked at GRP tube www.engineered-composites.co.uk/products...178637-4b9eb8c9-756f and this may be the cheaper alternative to our projects John. Although at 20mm inside dia the wall thickness would be 2.5mm. Although there is no price given and stock lengths are 6 mtr but can be cut down for transport.
John, your idea of using ally tube sounds feasible too. Sticking on an ally backplate or washer to allow wiring out and you have a lamp unit.
13 Mar 2019 11:30 #19053 by kevinross
Baldrick has a "Cunning Plan"
I have some litho plate which you could cut to the exact circumference and wrap around the 22mm tube. - then apply a ring of glass - but i think a better method wold be a spiral wrap of narrow cloth tape which can be stolen from the missus's sewing box. You could pre soak the tape or brush your "glue" through the cloth.
13 Mar 2019 12:36 #19054 by Phil Ford
That appears to be a "cotton and polyester" roll wrap Kevin.:lol:
It would be interesting to see how successful DIY tube creation whether grp or carbon could be.
Time to create page: 0.348 seconds
