Landing Gear Sequencer
20 Jul 2019 12:05 #20323 by Phil Ford
Landing Gear Sequencer was created by Phil Ford
Just arrived the replacement all metal nose gear for Valkyrie albeit this retract is for a Viper 90mm. I will also have to swap out the leg as the Viper is shorter than the Valkyrie. The retract is not electronic, ie; two wire system which means I need a sequencer to reverse polarity to the retract motor and another output, ie; 3 wire for PWM for gear door. Any suggestions on a cheap sequencer? MotionRc cannot help because all their retracts are electronic versions
20 Jul 2019 23:31 #20332 by 4Pedalsfly
Replied by 4Pedalsfly on topic Landing Gear Sequencer
Phil - Might be worth a look on Model Radio Workshop - www.modelradioworkshop.co.uk
21 Jul 2019 07:51 #20333 by Brian
Replied by Brian on topic Landing Gear Sequencer
Have a look at the nose gear doors of the FMS PC-21, passive operation no extra servo/electronics. I've got one if you'd like to see how its done.
22 Jul 2019 10:59 #20351 by Phil Ford
Replied by Phil Ford on topic Landing Gear Sequencer
The new all metal nose retract is only two wire. It does not have a signal wire like Eflite, Jetcraft, etc, where the electronics to reverse the motor are built in. Therefore it needs a controller (see example images below where you will see only two pins for the retracts on PilotRC and the RC Lander units) which switches the polarity to change direction of motor. In most cases the controller also sends PWM signals to servos for doors etc.
Really stuck on this issue to get an operating nose leg to work with minimum fuss.
22 Jul 2019 17:17 #20352 by MikeSeale
Replied by MikeSeale on topic Landing Gear Sequencer
Phil Ford wrote: Really stuck on this issue to get an operating nose leg to work with minimum fuss.
Minimal fuss = don't order retracts without a signal wire
22 Jul 2019 17:43 #20353 by John Bannister
Replied by John Bannister on topic Landing Gear Sequencer
I've still got this hobbyking front leg or I might be able to repair the old one
22 Jul 2019 18:27 #20355 by Phil Ford
joneb wrote: I've still got this hobbyking front leg or I might be able to repair the old one
Thanks John but the nose gear plate is quite large, in fact larger than most EFlite retracts. Bear in mind this leg has to take the weight of 90mm EDF. Looking at a whole set of retracts for giant scale turbine jets many use the two wire system as pictured in my images. But for one nose leg you wouldn't want to buy £120 worth of controller.;) Well I am not!
23 Jul 2019 07:19 #20356 by John Bannister
23 Jul 2019 08:48 - 23 Jul 2019 08:51 #20357 by Phil Ford
Thanks John, I did come across some projects using an Arduino. Although the Arduino for timings, etc but still require the signal (PWM) line. Anyway I have downloaded the ino file for later play. The gear I have needs the motor polarity reversing for up or down. Looking at a stripped down image of one these jet jockey controllers it looks like they use our old friend the STM8 chip (found in receivers, speed controllers, "you-name-it" and the motor control forward/reverse is switched by small chips but could not see in the photos what they were. Think they are LB11805 maybe.
Last edit: 23 Jul 2019 08:51 by Phil Ford.
29 Jul 2019 19:20 - 29 Jul 2019 19:22 #20436 by Phil Ford
Hawk eye John B spotted this controller for an Avios MIG17. Exactly what I need, two pin outputs to gear motors. :woohoo: Coming from Hong Kong though. £8.60 + £3.15 P&P
Thanks John.
Last edit: 29 Jul 2019 19:22 by Phil Ford.
Time to create page: 0.372 seconds
