Onboard Ignition Switches
  • Simon Osborne
17 Oct 2020 21:05 - 17 Oct 2020 21:10 #23482 by Simon Osborne
Onboard Ignition Switches was created by Simon Osborne
Today I learnt a valuable lesson. No drama thankfully but this particular flight could have ended in disaster when the ignition switch developed a fault.
Most of us with petrol engine models fit an on-board ignition switch that is operated from the transmitter.
The lesson I learnt is that there are versions of these ignition switches from as little as £8 and there are versions at the other end of the market circa £45. The old adage ‘you pays your money’ comes to mind.
Guess at which end of the market my replacement ignition switch will be coming from.
Simon O
Last edit: 17 Oct 2020 21:10 by Simon Osborne.
18 Oct 2020 10:45 - 18 Oct 2020 10:48 #23483 by JonTappin
Replied by JonTappin on topic Onboard Ignition Switches
Hi Simon
I think you've been a little unlucky, I've used a few RCexl switches and never had a failure, but if you want to go higher end, I would recommend the Powerbox Sparkswitch. Their products are very high quality, but you pay for it. I had one in my 104 Extra. Its a switch and regulator.
www.nexusmodels.co.uk/powerbox-spark-swi...ted-output-6610.html
Last edit: 18 Oct 2020 10:48 by JonTappin.
18 Oct 2020 11:12 - 18 Oct 2020 11:13 #23485 by Phil Ford
Replied by Phil Ford on topic Onboard Ignition Switches
I have had no issues with RCexl either although I don't buy them from Ebay, only from model shops. Not that you would buy anything from Ebay Simon! :lol:
Last edit: 18 Oct 2020 11:13 by Phil Ford.
  • Simon Osborne
18 Oct 2020 11:45 #23486 by Simon Osborne
Replied by Simon Osborne on topic Onboard Ignition Switches
Yes, I’ve ordered a power box unit. Interestingly 2 other members at the field yesterday have had RCxcl units fail.
With the luck I’ve had model flying recently I’m not prepared to take the risk. I call it ‘Insurance’ tactics. Of course the Powerbox unit could fail. Laws of averages I guess.:silly: :silly: :silly:
18 Oct 2020 14:33 #23487 by kevinross
Replied by kevinross on topic Onboard Ignition Switches
The Excel opto switch in my Stearman the original fitted approx 8 yrs ago - sourced from H/king. Also used 2 more in other models. Couldn't use one on the Decathlon due various limitations so thats a mini servo operated microswitch - even better that onto isolation !
Time to create page: 0.314 seconds
