Concrete advice
  • Mike Seale
21 Dec 2020 16:50 #23870 by Mike Seale
Concrete advice was created by Mike Seale
Completely not model related...looking for advice from anyone who might be able to help...
I've got a couple of statues for my garden that need to have bases formed in the flower beds. The statues are 1.5m tall and weight 140kg each (yes, that's not a typo - they are 22 stone each). The base is 360mm square. Does anyone know how deep and wide a concrete base should be?
21 Dec 2020 17:51 #23874 by JonTappin
Replied by JonTappin on topic Concrete advice
Sounds like one for Mr Dean!
21 Dec 2020 19:24 #23877 by simondean
Replied by simondean on topic Concrete advice
Hi Mike
I’d make concrete base 600mm square and have a depth of 150 mm concrete just to be on the safe side
If ground is ok underneath this depth it’ll be ok but if ground is poor put 100mm of base material ie crushed concrete or scalpings then compact before laying concrete.
Make sure you level and leave smooth or your statues won’t sit right
21 Dec 2020 19:30 #23878 by kevinross
Replied by kevinross on topic Concrete advice
Would one of these would help ? (couldn't resist - sorry)
22 Dec 2020 07:34 - 22 Dec 2020 08:10 #23884 by DaveBright
Replied by DaveBright on topic Concrete advice
Always good to get a concrete answer :-)
Last edit: 22 Dec 2020 08:10 by DaveBright.
  • Mike Seale
22 Dec 2020 09:33 #23885 by Mike Seale
Replied by Mike Seale on topic Concrete advice
Thanks, Simon. I'll follow your advice.
22 Dec 2020 10:09 #23886 by DavidTappin
Replied by DavidTappin on topic Concrete advice
If the statues look anything like Cecil Rhodes or Edward Colston I’d go for thicker concrete
22 Dec 2020 15:58 - 22 Dec 2020 16:02 #23888 by 4Pedalsfly
Replied by 4Pedalsfly on topic Concrete advice
Mike - At that weight it's unlikely
any of the local rouges will attempt to remove them, any chance of pics when erected ?
Last edit: 22 Dec 2020 16:02 by 4Pedalsfly.
22 Dec 2020 16:20 #23889 by Phil Ford
Replied by Phil Ford on topic Concrete advice
Colin Arnold wrote: Mike - At that weight it's unlikely
Rogues might Colin, in fact anything can be swiped if need be.:lol: Not sure about French Reds though.;)
Time to create page: 0.416 seconds
