Prop Balancing
  • Donald Moorcraft
04 Mar 2021 09:05 #24310 by Donald Moorcraft
Prop Balancing was created by Donald Moorcraft
Hi Guys, have 3 blade prop problem. 1 blade is extra heavy. unable to get blade 1, 2, 3 marked as heavy prop blade ends up pointing straight down. Have drilled several holes in it sanded the crap out of it and its still points straight down. I have ordered Master airscrew replacement as factory balanced. how would you advise sorting this problem
  • Mike Seale
04 Mar 2021 09:46 #24311 by Mike Seale
Replied by Mike Seale on topic Prop Balancing
Add tape to the light blade(s). Something like Sellotape crystal clear which is UV resistant.
04 Mar 2021 10:33 #24312 by JonTappin
Replied by JonTappin on topic Prop Balancing
I use superglue on the rear face, keep adding layers until balanced
The following user(s) said Thank You: Donald Moorcraft
04 Mar 2021 14:21 - 04 Mar 2021 14:21 #24313 by Phil Ford
Replied by Phil Ford on topic Prop Balancing
I use the wife's clear nail lacquer, dries real quick. Lay it on with brush either lightly or heavy. In the end she gave me the little bottle. :lol:
Last edit: 04 Mar 2021 14:21 by Phil Ford.
04 Mar 2021 19:03 #24316 by DaveBright
Replied by DaveBright on topic Prop Balancing
Phillip Ford wrote: I use the wife's clear nail lacquer, dries real quick. Lay it on with brush either lightly or heavy. In the end she gave me the little bottle. :lol:
And how do you balance a prop Phil?
  • Brian Jackson
05 Mar 2021 06:13 #24317 by Brian Jackson
Replied by Brian Jackson on topic Prop Balancing
This might seem daft, but is the mounting hole central? Manufacturing errors do happen, and quality inspectors do sometimes "let one through". I suggest this as I have a brushless motor that vibrates, I thought the shaft was bent and replaced it, there was no reduction in the vibration. Eventually and by accident, I found that the mounting hole for the prop shaft had not been drilled correctly and is at a slight angle, this throws the motor completely off balance. Unfortunately the motor was a Giant Shark purchase, just before they closed down so no chance of a replacement.
05 Mar 2021 08:59 #24318 by Phil Ford
:dry:
Same method as Jon. Did you not know? :lol:
05 Mar 2021 16:03 #24321 by 4Pedalsfly
Replied by 4Pedalsfly on topic Prop Balancing
Don - Don't know how you balance props, but a DuBro "Prop Balancer " just appeared on the BMFA website - Ad ref 104750.
He's also selling a servo lead crimping set - ad ref 104749.
p.s - Cannot help with nail manicure aids.
05 Mar 2021 17:57 #24325 by DaveBright
Phillip Ford wrote: :dry:
Humour gets lost in forum posts :-)
Time to create page: 0.318 seconds
