An Electrical Nut Required
03 Jul 2021 16:59 - 03 Jul 2021 16:59 #24852 by Phil Ford
An Electrical Nut Required was created by Phil Ford
The thin profile nut that holds a Dualsky fail safe switch in the fuselage has vibrated off. (Dualsky do not make this switch type anymore) I have rummaged through all my electrical stores but nothing. The switch thread is 8 mm. It probably is the same as would be used on electrical toggle switches. Anyone help?
Last edit: 03 Jul 2021 16:59 by Phil Ford.
03 Jul 2021 19:55 #24855 by kevinross
Replied by kevinross on topic An Electrical Nut Required
hope your not referring to me as an "electrical nut" before i give you this
04 Jul 2021 10:26 #24858 by Phil Ford
Replied by Phil Ford on topic An Electrical Nut Required
Kevin Ross wrote: hope your not referring to me as an "electrical nut" before i give you this
Why, of course not! That may just do the job. Thanks
04 Jul 2021 20:03 #24864 by John Bannister
Replied by John Bannister on topic An Electrical Nut Required
Phil did you loose it at the field if so it may be in the back of my car
05 Jul 2021 16:13 - 05 Jul 2021 16:13 #24865 by Phil Ford
Yes John. Somewhere between where I was parked next to you on Friday morning and directly forward to the flight line.
Last edit: 05 Jul 2021 16:13 by Phil Ford.
