3 blade spinner cutouts
16 Jul 2024 13:28 #26846 by kevinross
3 blade spinner cutouts was created by kevinross
A member asked me to cut out a spinner for 3 blade prop so being a gluten for punishment i said ok
Started by making a thin card template to fit one blade from which i made a curved alloy template - ( i used the thin alloy wrap from a scrapped lipo)
Used the template to optimise the blade position on one of the original cutouts.
Matching the other two cut outs was beyond my hand skills so used a tilting rotary table in the vertical mill
Then made a series of individual cuts and rotating the table 120 / 240 360 degree
but this became monotonous so removed the handle and fixed a drill to the shaft then fine tuned each position by hand
16 Jul 2024 13:32 #26847 by kevinross
Replied by kevinross on topic 3 blade spinner cutouts
continued
Finally blending was done with a rotary rasp and small sanding drum.
Like most things, the time was in the prep work  but it averaged an hour per cut out
16 Jul 2024 17:10 #26848 by Phil Ford
Replied by Phil Ford on topic 3 blade spinner cutouts
Wow, that was a bit work Kevin!  Looking forward to seeing it in the flesh
17 Jul 2024 11:02 #26852 by DavidTappin
Replied by DavidTappin on topic 3 blade spinner cutouts
Now I know where to go if I need a better job done than I usually make of spinner cut outs!
But I am wondering why, in ordrer to get punished, Kevin needs to be a protein found in the wheat plant and some other grains.
18 Jul 2024 10:21 - 18 Jul 2024 10:27 #26853 by Phil Ford
Yes, I wondered about that too. Gluten?  I think he means a glutton for punishment which also tells us that he will likely do it again shortly.  Dig out your ally spinners!
Last edit: 18 Jul 2024 10:27 by Phil Ford.
18 Jul 2024 21:51 #26854 by kevinross
I thought then spelling was wrong but then i thought - no worry, i know a man with the knowledge !!
The following user(s) said Thank You: superadmin
Time to create page: 0.488 seconds
