Durafly Vampire
4 years 5 months ago #24535 by Brian
Durafly Vampire was created by Brian
I want to replace the five blade EDF with a twelve blade unit. The Vampire's present unit seems to be firmly glued into the fuselage. I've seen on the Internet that the EDF just "pulls out" with considerable effort. I had an extra Weetabix for breakfast, but I still couldn't get the fan unit to budge. I've run a knife around the profile as deep as possible, but to no effect. Any suggestions?
4 years 5 months ago #24538 by MikeSeale
Replied by MikeSeale on topic Durafly Vampire
Crash it...the fan unit will then be easy to remove.
4 years 5 months ago #24539 by Phil Ford
Replied by Phil Ford on topic Durafly Vampire
Mike Seale wrote: Crash it...the fan unit will then be easy to remove.
:lol:
4 years 5 months ago #24542 by Brian
Replied by Brian on topic Durafly Vampire
I never though of that!
Anyone skilled in the art of selective crashing?
Must be able to identify the bits for re-assembly.
4 years 5 months ago #24543 by
Replied by on topic Durafly Vampire
It will come out if you are persistent Brian. I tried a 12 blade same pier as original and it was rubbish. Best setup I have found is the one in the Canadian edition
4 years 5 months ago #24544 by Brian
It occurred to me, (on the way back to the shed after reading the helpful remarks about fan removal) the fan is probably held in with hot glue. The weather is cold, the glue is hard and unyielding. OK. Apply hot air from heat gun to fan unit, when thoroughly warmed through, apply pressure. The photo proves that it worked. Kadet in background with front blue trim finished, awaiting some idle bloke to apply finishing touches (black pin stripes)
Time to create page: 0.254 seconds
