Freewing F9F Panther 64mm EDF
  • Elliott
15 Feb 2022 14:45 #25572 by Elliott
Freewing F9F Panther 64mm EDF was created by Elliott
Just ordered one of these, been umming for a while over getting one, and seen they are popular at the club.
Any issues using 2200 3s, any mods when building them, or build it stock?
15 Feb 2022 15:45 - 15 Feb 2022 15:50 #25574 by Phil Ford
Replied by Phil Ford on topic Freewing F9F Panther 64mm EDF
2200 maH 3 cells up front as far as it will go which usually is the front edge of the hatch area. I found with a 2200 Zippy compact I had to add 25gms into the nose. Other than that keep stock. I have 35% expo on all surfaces. Minimal ailerons, max elevator, expo to suit your style Elliot. :lol:
Launching? I cannot do under arm launch so I have cut away two air intake ribs inline with CG underneath. Lets your fingers grip the fuselage easier and launch it like a javelin....;)
Last edit: 15 Feb 2022 15:50 by Phil Ford.
The following user(s) said Thank You: Elliott
15 Feb 2022 18:38 #25575 by kevinross
Replied by kevinross on topic Freewing F9F Panther 64mm EDF
You might look at my post , this mod makes launching easy.
wimbornemac.org/forum/jet-flight-edf/296...ther-launching#25437
Ive bought 1800mA batteries which slide fully into the nose and balance well . Ive also flown with a 2200 like phil but it needs to be no thicker than 22mm or the canopy may not close
18 Feb 2022 17:58 #25581 by JonTappin
Replied by JonTappin on topic Freewing F9F Panther 64mm EDF
Stock set up is fine with 2200 3s Elliot, like others have said, it might need a few grams of lead as well.
I find mine easy to launch overarm, just gripping the fus in front of the intakes. Careful with the aileron throw, it will roll very quickly with too much, don't ask me how I know :)
Time to create page: 0.556 seconds
