Jet & D.F Day - Sunday 6th May
  • 4Pedalsfly
29 Aug 2015 23:49 #5666 by 4Pedalsfly
Jet & D.F Day - Sunday 6th May was created by 4Pedalsfly
Above event coincides with the last day of the Steam Fair, on the Sunday the event finishes at 3.00 pm
We all aware of the traffic generated in the area, so is it worth considering moving it to the following Sunday
the 13 th ?
Also is non Jet / D.F flying o.k. ?
Colin. A
  • 4Pedalsfly
29 Aug 2015 23:53 #5667 by 4Pedalsfly
Replied by 4Pedalsfly on topic Jet & D.F Day - Sunday 6th May
Oops ! - Should read 6th September
Colin. A
  • Phil-C
30 Aug 2015 09:59 #5668 by Phil-C
Replied by Phil-C on topic Jet & D.F Day - Sunday 6th May
Thanks, Colin, The event is currently planned for next Sunday, 6th Sept. There is nothing planned for the following Sunday, 13th.
My vote would be YES, lets move it.
Please post on here if you agree.
30 Aug 2015 11:34 #5671 by MikeSeale
Replied by MikeSeale on topic Jet & D.F Day - Sunday 6th May
Too late to be having this discussion...leave it where it is.
The delay you will experience going to or returning from the field is minimal compared to the 2-3-4 or more hours you are going to spend at the field. And if you want to reduce your delay even more, take a look at a map and take a few back roads. For example, take a left at the bottom of the hill in Cashmoor to take the road that runs parallel to the 'Horton' road. Drive all the way up through Wimborne St Giles and end up on the Cranbourne road.
  • Phil-C
30 Aug 2015 13:25 - 30 Aug 2015 13:28 #5672 by Phil-C
Let's see what the weather brings. Right now, the XC forecast is 12 to 14 mph gusting 20 NNE to N.
Holding it a week later has no impact. It's only a Club event, unless David has invited someone.
Last edit: 30 Aug 2015 13:28 by Phil-C.
30 Aug 2015 21:50 #5683 by DavidTappin
Replied by DavidTappin on topic Jet & D.F Day - Sunday 6th May
No invitees as far as I know, We (the committee) had discussed inviting other clubs which Phil C was going to do as I am in Germany for the JWM and won't be home until Friday Sept 4th. I'll leave decisions about moving the date to the committee. As I won't have a turbine for my Boomerang (see the Wren topic) it makes little difference to me.
The weather here in Germany is perfect, not a breath of wind and around 30 degrees during the day. Maybe they should hold the Nats here.
Regards, David
  • DaveA
31 Aug 2015 13:00 #5690 by DaveA
Replied by DaveA on topic Jet & D.F Day - Sunday 6th May
Couldn't have picked a worse day than 6th. There will be much traffic congestion. Why too late to move it. It hasn't got outside invitees to consider. And as the man says the weather does not look good.
Time to create page: 0.294 seconds
