DIY fod guard
07 Oct 2015 14:11 - 07 Oct 2015 14:12 #6370 by flyingpete
DIY fod guard was created by flyingpete
This is not a new idea but I thought I would share.Fod guard's are critical to have on your turbine as they stop foreign matter being sucked in and a cheap easy way to make one is spend £2.47 on a tea strainer.Simply make a hole slide it over the starter motor and secure with a under size rubber o ring job done.The list price for a fod for my pst turbine is £ 26.00 plus shipping.
Last edit: 07 Oct 2015 14:12 by flyingpete.
07 Oct 2015 15:19 #6371 by JRI
Replied by JRI on topic DIY fod guard
Don't underestimate the local sucking power. I think you would be well advised to seal the gap between the strainer and the turbine. I used silicone fuel pipe slit down its length and then use silicone sealant to attach it as a permanent flexible gasket to the strainer.
07 Oct 2015 17:55 - 07 Oct 2015 17:58 #6372 by kevinross
Replied by kevinross on topic DIY fod guard
Like JRI , I would also be concerned about the air restriction this idea might cause. I think you may need a much greater cross sectional area without restricting the air flow.
To explain see these examples of the full size to demonstrate the mass air flow a jet produces.
Last edit: 07 Oct 2015 17:58 by kevinross.
07 Oct 2015 19:29 #6373 by flyingpete
Replied by flyingpete on topic DIY fod guard
Thanks for your views guy's.I am fully aware of the sucking power of a turbine as it's about the same as the wife's intake of breath when I'm in her bad books
08 Oct 2015 18:30 #6375 by DaveBright
Replied by DaveBright on topic DIY fod guard
Good solution Pete. Even HobbyKing are selling Fod guards now.
08 Oct 2015 19:15 #6378 by Phil Ford
Replied by Phil Ford on topic DIY fod guard
flyingpete wrote: the sucking power of a turbine as it's about the same as the wife's intake of breath when I'm in her bad books
Or Pete, "wife's intake of breath when you tell her how much that plane was"
In my case it's the outgoing blast of breath I have to avoid as I mumble the price....... :lol:
Time to create page: 0.528 seconds
