Cutting thin slots in hard wood
  • JRI
16 Jan 2018 18:59 #15430 by JRI
Cutting thin slots in hard wood was created by JRI
I am using fuzzy hinges on my Mig.3 rudder. But the rudder post on the fin is made of hard ply and I cannot get a scalpel blade through it. I have tried using a thin dremel wheel on ply but it cuts a slot wider than 0.5mm whereas the fuzzy hinge is 0.25mm thick. Anyone got any clever ideas?
16 Jan 2018 19:50 #15431 by MikeSeale
Replied by MikeSeale on topic Cutting thin slots in hard wood
1. Use Robart hinge points instead and simply drill through your fin post
2. Drill a, say, 1/8 hole above and below where you want the hinge and remove the ply between the holes using a fine saw or file. Replace with balsa.
3. Find a multitool (Google multitool) that has fine blades. I got a cheap multitool before Christmas and it's amazing how easily it cuts through wood and aluminium. If you can find a hobby version with finer blades please share.
16 Jan 2018 20:08 #15432 by Chris001
Replied by Chris001 on topic Cutting thin slots in hard wood
I've never tied them John, but often thought they might be handy:
www.shesto.co.uk/hand-tools/saws-and-saw...with-scalpel-handle/
0.24mm
16 Jan 2018 20:17 #15433 by JonTappin
Replied by JonTappin on topic Cutting thin slots in hard wood
I would go for Mike's first suggestion, Robarts are better for large models and easier to install
  • JRI
16 Jan 2018 21:31 #15435 by JRI
Replied by JRI on topic Cutting thin slots in hard wood
Trouble is I have already slotted the rudder. My logic is that the rudder post and rudder leading edge do not mate very well and fitting strain-free robarts would be a tough call (otherwise I totally agreee that they are the easy option). So I love the sound of the shelsto micro saws and will post with results when they arrive.
  • JRI
16 Jan 2018 21:54 - 16 Jan 2018 21:59 #15436 by JRI
Also not enough 'meat' on the fin post to support robarts. The fin strength is in the composite skin..., Note the warped post which makes for gaps between the fin and the rudder... And there's a pull-pull elevator mechanism to still fit in the void which may clash with robarts or extra thickness to the post
Last edit: 16 Jan 2018 21:59 by JRI.
17 Jan 2018 00:22 #15438 by kevinross
Replied by kevinross on topic Cutting thin slots in hard wood
based on your commitment to fuzzy hinges and create a narrow slot, I would make two bevelled hardwood blocks which could be glued with the appropriate gap . Then use this jig to drill multiple holes at the correct angle and in a straight line. Then you should be able to join the holes with a scalpel.
The following user(s) said Thank You: JRI
