KS Tuned Pipe: Willie Warmer
  • JRI
02 Mar 2018 16:59 - 02 Mar 2018 17:15 #15847 by JRI
KS Tuned Pipe: Willie Warmer was created by JRI
[This K&S tuned pipe from probuild will be inside my Mig.3 fuselage to keep the model's clean scale lines, boost midrange power, and give good silencing. With a 55cc 3W motor up front I wanted to make sure that as little of the potential heat as possible escapes the skin of the pipe so (with a little help from a friend) I sewed up this Nomex sock to surround the pipe ! Almost no weight and fireproof.
If you watch it long enough it moves ...
Last edit: 02 Mar 2018 17:15 by JRI.
02 Mar 2018 22:36 #15854 by 4Pedalsfly
Replied by 4Pedalsfly on topic KS Tuned Pipe: Willie Warmer
John- I'm looking for a fire proof material to line my metal LiPo charging box, pls advise source
of " Nomex
Thanks
  • JRI
03 Mar 2018 07:43 #15855 by JRI
Replied by JRI on topic KS Tuned Pipe: Willie Warmer
Hi Colin, search for "8oz* - NOMEX - FIRE RETARDANT - FABRIC MATERIAL CLOTH " in ebay.
Please note it is fire retardent and not fully flameproof. I also use proper aluminium foil "Exhaust Turbo Heat Shield Wrap Mat 1m x 1m - Aluminium Foil Backed Glass Fibre" for the hotter exhaust manifold - this may be a better bet. PS this website prevents posting of ebay links so you will need to do searches for the items.
03 Mar 2018 15:34 #15861 by 4Pedalsfly
Thanks John - I'm now on the case.
