Rubin
5 years 5 months ago #21957 by MikeSeale
BTW, I placed an order with Model Shop Leeds yesterday afternoon and it was delivered this morning.
5 years 5 months ago #21958 by MikeSeale
Sub-fin added and sanded to shape
5 years 5 months ago #21959 by MikeSeale
Wings cut. Retract plate added.Another plate is added to the top of the wing and 5mm dowels tie both surfaces together so that landing loads are spread through the whole wing...hopefully!
5 years 5 months ago #21960 by MikeSeale
Wing skins made from six sheets of 4" balsa and 1 sheet of 3". This is for just one half, so a total of 12 x 4" and 2 x 3" sheets in total...it's a big wing!
5 years 5 months ago #21961 by Phil Ford
What are you using to join the sheets? Excellent progress Mike but you will have nothing left to do by Easter Weekend and then what? :lol:
5 years 5 months ago #21962 by MikeSeale
Tape sheets together with masking tape. Turn over and use the tape as a hinge to open the joint. Aliphatic glue then pinned flat for a couple of hours. Unpin and remove tape sooner rather than later. Leave it too long and the tape sometimes stays stuck to the joint.
The good side is the taped side.
Time to create page: 0.292 seconds
