Curare 60 E
5 years 6 months ago #22063 by Brian
Replied by Brian on topic Curare 60 E
Simon, if you're going to use rude words like "Instruction Manual" I'm not going to read your article so there!
5 years 6 months ago #22065 by
Replied by on topic Curare 60 E
Brian I usually use Instruction manuals to stand my tea on! Haven't you seen the state of my models!
5 years 6 months ago #22067 by Brian
Phew! That's a relief Simon.
5 years 6 months ago - 5 years 6 months ago #22069 by
Having cut the grass, aerated front and back lawns and applied the grass fertiliser it meant I could spend some time on the Curare.
First job was to carefully cut the covering under the wing bolt strengthner plate position and glue the plate in place.
The system of linking the flaps was a first for me, so pleased to have accomplished this job, setting up still to do.
Good news continued when it came to installing the Extreme Flight 4016T motor. To get the propeller drive plate on the end the motor to stand clear of the front of the cowl needed just 2 washers behind each bolt securing the motor to the motor box. Excellent fit.
Wonder what tomorrow will bring.
Last edit: 5 years 6 months ago by .
5 years 6 months ago - 5 years 6 months ago #22070 by Phil Ford
Looking good Simon. Re- your flap control rods. Slightly bend the rods so that the clevises are not kinked over as in your photo. They will pull out otherwise. Also slide some silicon tube over them too to lock them on.
Last edit: 5 years 6 months ago by Phil Ford.
5 years 6 months ago #22072 by
Thank you for the advice Phil.
When I finish the instal I will do so.
Time to create page: 0.292 seconds
