Help with choosing covering film
  • ruggerbloke
  • Junior Member
  • Junior Member
30 May 2020 10:39 #22653 by ruggerbloke
Help with choosing covering film was created by ruggerbloke
Hi all. Having got back into building after a long absence, I plan to use transparent covering film. It appears that Oracover/Profilm is the preferred make, but at a premium cost. Is it a case of "You get what you pay for" as regards to covering film? I have seen the colours I like on Ebay by Sparkside RC -Thomas Foster at a vastly reduced price. Has anyone had any experience of this covering? Any advise is much appreciated.
30 May 2020 12:00 - 30 May 2020 12:01 #22654 by Phil Ford
Replied by Phil Ford on topic Help with choosing covering film
Welcome Denis to Wimborne MAC.
With the sad demise of SolarTex/Solar Trim there are only a few choices. Personally I prefer Oracover/Ultracote because they match most of my planes original coverings. There is a similar alternative and much cheaper from Hobbyking although I find their polyester covering a little thicker (talking microns here) but many on here have used it successfully.
Last edit: 30 May 2020 12:01 by Phil Ford.
30 May 2020 13:33 #22655 by MikeSeale
Replied by MikeSeale on topic Help with choosing covering film
The film sold by sparkside is from hobbyking. So you can get it even cheaper if HK has it in stock but shipping might swing it in sparksides favour if you're only ordering a couple of rolls.
I've used HK covering for several years and like it very much. Unlike Phil, I think it is thinner than Profilm and a lot easier to work with around compound curves. I think profilm is possibly a little more stable and does not need re-shrinking as often.
For me, the real advantage is that you don't have to be so careful when you cut pieces from a 5m roll because there's plenty if you make a mistake. I'm sure we've all done it before where we cut a piece of profilm from their 2m rolls only to find that it doesn't fit because you've not given yourself enough of an overlap.
BTW, Tom Foster was/is a WMAC member.
  • ruggerbloke
  • Junior Member
  • Junior Member
30 May 2020 17:12 #22658 by ruggerbloke
Replied by ruggerbloke on topic Help with choosing covering film
Thanks Phil and Mike. I have seen good reviews of HK covering elsewhere. As the Oracover colour that I want is pretty much out of stock in the UK, I have ordered a couple of rolls from Tom at Sparkside. I will probably make a few mistakes on my first attempt at covering, so not paying too much is a bonus. Maybe I'll try Oracover when I get more experience at covering. Winning the Lottery will also help. Thanks for your input.
Time to create page: 0.247 seconds
