How to remove cyano from a film covered model
  • ruggerbloke
  • Junior Member
  • Junior Member
01 Oct 2020 20:09 #23427 by ruggerbloke
So, I was a bit heavy handed with thin cyano when gluing some aileron tabs. I put some on the top side of the tabs all o.k. When I tuned it over to do the other side, thin cyano had smeared across the wing. I attempted to clean it up using cyano debonder, but it looks even worse now. Could anyone offer any advice on how to do this if it's possible? Perhaps I should have left the debonder on longer, rather than trying to wipe it immediately. Help!!!
01 Oct 2020 20:55 #23428 by DaveBright
Replied by DaveBright on topic How to remove cyano from a film covered model
More debonder and leave it for 15 mins to soften the cyano. Wipe and repeat.
I’ve found the Loctite debonder particularly good
www.diy.com/departments/loctite-glue-remover-5g/254758_BQ.prd
  • ruggerbloke
  • Junior Member
  • Junior Member
02 Oct 2020 07:29 #23429 by ruggerbloke
Replied by ruggerbloke on topic How to remove cyano from a film covered model
Thanks Dave, I'll give that a go.
02 Oct 2020 08:12 #23430 by JRI
Apply the debonder to a piece of kitchen roll on top of the cyano and leave it soak up the cyano as it liquidises (5 mins?). Wipe and repeat with clean roll until done but don't leave it to dry as the cyano will rebond the paper to the covering.
  • ruggerbloke
  • Junior Member
  • Junior Member
02 Oct 2020 10:07 #23431 by ruggerbloke
Thanks John, I'll give this a go. Cheers
02 Oct 2020 14:33 #23434 by JonTappin
Replied by JonTappin on topic How to remove cyano from a film covered model
As above Dennis, sometimes it just needs a bit of patience and a few applications to get it all off.
Don't use debonder on clear canopies though!! Speaking from experience :(
  • ruggerbloke
  • Junior Member
  • Junior Member
02 Oct 2020 18:40 #23436 by ruggerbloke
Thanks Jon. Luckily the canopy is not affected. I've started as per recommendations and it is looking better. I think several applications should do the trick. Cheers all.
Time to create page: 0.285 seconds
