On The Eastern Front
  • JRI
14 Feb 2016 14:44 - 14 Feb 2016 14:51 #8006 by JRI
On The Eastern Front was created by JRI
After a number of moral improving 'shootings' the Colehill Mikoyan Guravich factory collective have made significant progress on the Mig3.
A 3W 55i has been installed and the manifold tuck away inside the fus' awaiting a K&S tuned pipe to be attached. The wing has been installed and mounting plates and pins in complete accordance with the chinglish instruction 'attach wing using components - incorrect here will result in crash'. ESM electric retracts to be installed next then epoxy tail and wing panels.
Last edit: 14 Feb 2016 14:51 by JRI.
14 Feb 2016 15:02 #8007 by flyingpete
Replied by flyingpete on topic On The Eastern Front
Very nice John B)
14 Feb 2016 17:54 - 14 Feb 2016 17:56 #8009 by Phil Ford
Replied by Phil Ford on topic On The Eastern Front
A big MIG! Looking good John.
Looks like this year could be '44 again with the known war bird fans for 2016....... ;)
You do realise John that if you run out of fuel you are expected to crash it into a worthwhile target. for the motherland.
Last edit: 14 Feb 2016 17:56 by Phil Ford.
14 Feb 2016 20:36 #8014 by AlanF
Replied by AlanF on topic On The Eastern Front
Excellent stuff John - What's your verdict on the quality of the kit and ease of build?
14 Feb 2016 22:02 #8015 by DaveBright
Replied by DaveBright on topic On The Eastern Front
PhilF51 wrote: ......you are expected to crash it into a worthwhile target. for the motherland.
:silly:
  • JRI
15 Feb 2016 11:31 #8021 by JRI
Replied by JRI on topic On The Eastern Front
AlanF wrote: Excellent stuff John - What's your verdict on the quality of the kit and ease of build?
Excellent quality fibre-glass fus and cowl - very strong and heavy duty. Nicely made built-up wings too. Canopy is a bit brittle and the wheel wells need some fettling to fit into the wing, but overall very pleased.. First time I have seen a pull-pull system for the rudder and both individual elevators. Has a large 3 piece split air-brake/flap so should be able to land pretty slow.
However, not a beginners model as some of the instructions need interpretation and wing and motor and exhaust installation needs some thought and measurement. I just love the look of the MiG3 and some of the other 50cc ESM YT International models are also quite unique ...
www.ytinternational.co.uk/raiden/raiden.htm
www.ytinternational.co.uk/la7/la7.htm
Time to create page: 0.483 seconds
