Fsky Taranis X9D Plus
7 years 9 months ago #14149 by MikeSeale
Well done, Brian. When you select a new model do you get the 'wizard' popping up like I showed you at the weekend?
7 years 9 months ago #14152 by Brian
Hello Mike, yes it's there, asking questions, just as you showed me last Sunday. Must admit, when the mouse pointer vanished when downloading the Betaflight Zadig program, I thought I'd never get to the point where I could program the Taranis . Now it's up to date, I'm beginning to feel confident that I'll be able to load in my first model.
Thank you for the help and encouragement.
7 years 9 months ago #14154 by MikeSeale
You're welcome, Brian. One final thought...since the transmitter is second-hand you should make sure that it is running EU-LBT firmware. This is not the same as the OpenTX software used to program models, it's the protocol used for transmitting. The reason to make sure it is EU-LBT is that (1) it is the 'legal' protocol in the UK and (2) when you buy new receivers they will be EU-LBT and it is going to be much easier to convert the firmware once in the transmitter rather than every time you get a new receiver.
7 years 9 months ago #14156 by Phil Ford
Brian wrote: Must admit, when the mouse pointer vanished when downloading the Betaflight Zadig program.
Zadig? I thought Zadig (USB driver library) was not needed for later stuff. I did not need it with Win10 and OpenTX2. My TX refused to talk back to my PC until I installed the later OpenTX 2.1.9. . Ver 2.1.7 was faulty apprarently.
Glad your sorted now....:) Welcome to the newbies club
7 years 9 months ago #14157 by Brian
Phil, I must admit that "Zadig" sounded more like a character from Flash Gordon, than a driver program. However, that obstacle has been overcome. I shall sleep easy tonight, especially since I saw that the mode on my X9D shows a comforting "D16". So my second hand bargain is EU compliant, crikey!
Thanks for the heads up Mike.
7 years 8 months ago #14198 by Brian
Getting to grips with the Taranis X9D+ isn't exactly what I thought. As bought, the transmitter had a model set up "Wizard". Since I upgraded the Tx to version 2.2, the Wizard has gone somewhere. Do I need to download a "fix" from OpenTx? Bit nervous about plugging in since I spent a day getting my mouse and keyboard working after the business with the "Zadig" download for a USB driver wiped them.
Time to create page: 0.276 seconds
