Servo repair
16 Jan 2018 10:51 #15422 by kevinross
Servo repair was created by kevinross
My S Bach 342 aileron servo did not operate smoothly during pre flight check on Sunday. It was apparent that the output gear was damaged and a new JR DS 386 is £45 so thought it was worth investigating.
The output gear was easy to extract. It needed a 1mm pin to drive out the brass end stop pin. Drilled a new hole to relocate the stop pin and the damaged tooth.. The most challenging bit was not dropping the minute brass stop pin into the abyss of my workshop floor !
This Yorkshireman is now happy he didn't have to buy a new servo.
16 Jan 2018 17:27 #15426 by flyingpete
Replied by flyingpete on topic Servo repair
kevinross wrote: My S Bach 342 aileron servo did not operate smoothly during pre flight check on Sunday. It was apparent that the output gear was damaged and a new JR DS 386 is £45 so thought it was worth investigating.
I bet the said Yorkshire man reuses his time bag's as well!!
16 Jan 2018 18:33 #15428 by Phil Ford
Replied by Phil Ford on topic Servo repair
flyingpete wrote: This Yorkshireman is now happy he didn't have to buy a new servo.
I bet the said Yorkshire man reuses his time bag's as well!![/quote]
Pete, it is well known fact that a Yorkshire man is very careful when it comes t' spending money. Knowt spent this time lad....;)
Time to create page: 0.268 seconds
