Spectrum DX6 Fault
7 years 2 months ago #17314 by
Replied by on topic Spectrum DX6 Fault
Hi Colin, No I have not re-bound my TX to plane, but as you can see by other posts the TX is now working to the Plane ok.
thank you Ernie
7 years 2 months ago #17315 by
The Master
7 years 2 months ago #17317 by 4Pedalsfly
Replied by 4Pedalsfly on topic Spectrum DX6 Fault
FlyBuster18 wrote: The Master
Ernie - Since your tx was the MASTER was a buddy lead being used with one of the club's older txs being the SLAVE ( ie not wireless ) ?
Thanks
7 years 2 months ago #17318 by
Colin originally my TX was set up by Mike Searle to work to one of the clubs older TX"s Both as mode 2. This always works well until a member wanted to train me with him using Mode 1 on my TX as master and me using Mode 2 on the same club slave. thats when it went to pot!
7 years 2 months ago - 7 years 2 months ago #17320 by 4Pedalsfly
FlyBuster18 wrote: Colin originally my TX was set up by Mike Searle to work to one of the clubs older TX"s Both as mode 2. This always works well until a member wanted to train me with him using Mode 1 on my TX as master and me using Mode 2 on the same club slave. thats when it went to pot!
Ernie - Assuming your TX was set back to Mode 2 correctly there should no longer be a problem since the Club have dedicated Mode 2 & Mode 1 Spectrum DX6e
wireless transmitters for training purposes.
I fly Mode 1 & would name & set up your model in the master TX model memory then bind it to your model.
You would then bind your own TX to the receiver in the Master transmitter & away we go - no buddy lead.
Having read the other postings it would appear that there is a problem when a Buddy Lead is plugged into your transmitter,
- that needs resolving.
Last edit: 7 years 2 months ago by 4Pedalsfly.
7 years 2 months ago #17328 by
I will have to check it may be a faulty socket !
Time to create page: 0.231 seconds
