DSX9 Settings Changed?
08 Jan 2019 14:35 #18618 by Phil Ford
DSX9 Settings Changed? was created by Phil Ford
Without going into the short story I have been getting all the petrol planes out and running again. Don't want them drying out.
Pitts Python was first this morning. It has been flown once by Jon with no issues except needed some more ballast on the engine box. That was shortly after the maiden. Nothing has been touched since then including the model settings in the TX.
So, before attempting to fire up just check the surfaces and that the throttle moves and the ign off switch works. Strange! Ign off did not work and I always assign my ign cut to the trainer switch on Aux4. Check TX and there is nothing programmed! Sorted that out and then spent ages trying to get the engine started. Nothing! Cowl off to have look in. Plug out and checked. Some fuel down the carb mouth, etc, etc. Nothing! whilst staring at the engine I noticed that the throttle arm appears to be going the wrong way. How can that happen? Reversed the servo and bang the engine ran after three flips.
Bottom line is has anybody come across this before on JR, ie settings getting lost?
08 Jan 2019 16:41 #18619 by kevinross
Replied by kevinross on topic DSX9 Settings Changed?
I have two of the same unit and never had any problems but i seem to recall Flying Pete had similar issues.
08 Jan 2019 16:48 #18620 by JonTappin
Replied by JonTappin on topic DSX9 Settings Changed?
I've never had this happen on any JR radio in the 30+ years I've been using it, but I've never owned a DSX9.
Sounds very strange to lose 2 different settings, are you sure you couldn't have changed something by mistake?
08 Jan 2019 19:00 #18628 by Phil Ford
Replied by Phil Ford on topic DSX9 Settings Changed?
I don't think I have changed anything Jon. The only time I have had an issue was with the first Curare having the ailerons going up together but I blame myself that time because I could not think of anything else.
As I now have a DSX11 I will copy all the models (manually) as a back up and maybe later rebind all models to the DSX11
09 Jan 2019 13:11 - 09 Jan 2019 13:11 #18639 by Phil Ford
DSX11 and Zero owners. According to the manual if a SD card is inserted you can save settings to the card. Manual is a bit ambiguous but can I assume you can copy card data back to the TX?
Last edit: 09 Jan 2019 13:11 by Phil Ford.
09 Jan 2019 13:20 #18640 by MikeSeale
Replied by MikeSeale on topic DSX9 Settings Changed?
Phil Ford wrote: DSX11 and Zero owners. According to the manual if a SD card is inserted you can save settings to the card. Manual is a bit ambiguous but can I assume you can copy card data back to the TX?
It would be a completely useless feature if you couldn't!
09 Jan 2019 13:40 #18641 by Chris73
Replied by Chris73 on topic DSX9 Settings Changed?
Yes you can, the manual for the zero is quite simply a waste of paper
Google is usually your friend for anything Zero related, there is loads of info out there
