DSX 9 Gimbal
09 Oct 2020 17:15 - 09 Oct 2020 17:17 #23449 by Phil Ford
DSX 9 Gimbal was created by Phil Ford
Today I have noticed that when bringing the throttle down to low if I pulled a little too hard back it acts as throttle cut. In other words it going past the near end of the pot. Needs replacing and have contacted Mike at Model Radio. This may be some of the issues that I have had with throttling down on IC engines. Might be the end of life for this DSX9. :(
Last edit: 09 Oct 2020 17:17 by Phil Ford.
09 Oct 2020 20:18 #23450 by JRI
Replied by JRI on topic DSX 9 Gimbal
Most higher end transmitters have a stick calibration feature - have you checked your manual?
09 Oct 2020 23:36 #23451 by kevinross
Replied by kevinross on topic DSX 9 Gimbal
John Ireland wrote: Most higher end transmitters have a stick calibration feature - have you checked your manual?
Never seen anything in my DSX9 manual re stick calibration. Although it was the first JR unit to adopt DSM2 RF protocol, i think the firmware dates to pre 2010.
  • Brian Jackson
10 Oct 2020 08:17 #23452 by Brian Jackson
Replied by Brian Jackson on topic DSX 9 Gimbal
Can you find the Service Manual for the DSX9 Phil? Years ago I had problems with an early JR X-347, sorted it using the JR service manual, which gave instructions for a factory reset procedure.
  • Brian Jackson
10 Oct 2020 08:33 #23453 by Brian Jackson
www.rcheliwiki.com/JR_9XII_service_menu
Here's a link that mentions the DSX9 as well as the 9X11
  • Brian Jackson
10 Oct 2020 12:25 - 10 Oct 2020 12:30 #23454 by Brian Jackson
Phil, I just tried this routine on my DSX9 and I can get it to go to factory settings. It might solve your throttle prob.
Last edit: 10 Oct 2020 12:30 by Brian Jackson. Reason: .JPG file added
  • Brian Jackson
11 Oct 2020 13:19 #23457 by Brian Jackson
This is the part of the program that sorts out the gimbals (sticks).
Stick Nut
This page sets the stick neutral positions. Each channel shows two values
The top value is the stick position with the centre offset applied. Ideally it reads zero when the stick is centred.
The bottom value is the the centre offset, and is quite probably not quite zero.
The values are for the two main gimbals, and also for the sliders on each side of the transmitter.
[ENT] returns to the service menu.
[CLR] clears the centre offsets.
[STO] stores the current stick and slider positions as their centre positons. It will then be necessary to to
[Stick Ga.]
Interestingly, it shows that the stick positions are probably quantized into about 900 discrete values.
11 Oct 2020 17:05 #23458 by kevinross
Very interesting Brian
Obviously not in the manual and i confirm this process works on my DSX9 (although this video is based on a PCM9)
Time to create page: 0.311 seconds
