F14 developed a radio fault
  • Wingman1962
19 Dec 2020 19:12 #23852 by Wingman1962
F14 developed a radio fault was created by Wingman1962
Hi. Could do with a few suggestions on how I could sort out a fault in the radio on my Freewing F14. The model has had a few flights and seemed ok. I stripped the model down to carry out a few repairs and to remove the retracts in order to reduce weight with the intention of using a bungee to launch it. During set up I noticed that the right taileron had developed a really bad glitch whenever the rudders or elevator are operated. I have tried a few things to try and sort it out, the receiver battery is fully charged, I have re-bound the receiver a couple of times, I have swapped the receiver for one that I know is ok and I have tried using a different transmitter and I have replaced both elevator servos. The only other thing I can think of doing is bypassing the onboard integrated circuit module unless anyone has any other idea what may be causing it that I could try. Thanks John
19 Dec 2020 20:26 - 19 Dec 2020 21:03 #23853 by DaveBright
Replied by DaveBright on topic F14 developed a radio fault
John, are you using FW’s ‘bluebox’ ? Is this the module you mention? If so, yes, try and bypass that. I took mine out of the T33, not because I had issues with it but had read of some that supposedly had.
Last edit: 19 Dec 2020 21:03 by DaveBright.
  • Wingman1962
19 Dec 2020 21:55 #23854 by Wingman1962
Replied by Wingman1962 on topic F14 developed a radio fault
Its the module that is supplied with the model. I think I could bypass it completely and just use the elevon mix on the transmitter. I will give it a go tomorrow. Thanks
20 Dec 2020 12:13 #23859 by Phil Ford
Replied by Phil Ford on topic F14 developed a radio fault
Yep, dump the module and use your TX for mixes. I had similar issues with a Taft EDF a few years ago, I pored over the circuit board for dodgy tracks/headers, etc. Surfed the "Net" and nearly everyone said dump the board and plugged in direct. Open TX gave me 8 -16 channels so plenty of options.
  • Wingman1962
20 Dec 2020 18:19 #23863 by Wingman1962
Ok managed to bypass the onboard circuit module, and after a fair bit of head scratching got the tailerons and every thing else directly programmed into the transmitter and that has sorted it out, thanks Dave and Phil. Next got design and make a ramp to launch it from.
20 Dec 2020 19:15 #23864 by kevinross
Replied by kevinross on topic F14 developed a radio fault
No idea what size your tomcat is but i use one of these for my Impressivio
hobbyking.com/en_us/pedal-operated-bunge...embly.html?wrh_pdp=1
21 Dec 2020 10:46 - 21 Dec 2020 10:49 #23868 by Phil Ford
Kevin's ramp is light weight so if your TomCat is fairly heavy then you need to make one out of 50mm waste pipe, rivets and a ply foot pedal like what I have. Plus 10 meters of surgical bungy doubled up too. Have you not seen mine John??? It is 2 meters long with 20 degree slope. Two meters is just enough to get it to flying speed. I have used it to launch wings, EDFs or anything with a hook. See the post below.
wimbornemac.org/forum/roll-calls/2498-tu...-june?start=10#22815
Might be worth trying out on mine to see if it will work for you. Any weaponry underneath might line up with launch tubes though. Hook position is critical though, forward of CG.
Last edit: 21 Dec 2020 10:49 by Phil Ford.
  • Wingman1962
21 Dec 2020 16:54 #23871 by Wingman1962
Thanks for that Kevin, but this is a pretty big plane and I cant really sit it on its wings to launch it because of the swing wing mechanism.
  • Wingman1962
21 Dec 2020 17:06 #23872 by Wingman1962
Yeah that ramp of Kevins is not going to work. Because of the weight of the model sitting on the wings and the swing wing mechanism and the close proximity of the tailerons launching it from that type of ramp is going to be difficult. I think it would have to be quite simply of a flat smooth board. I have protected the foam under the fus with some clear Perspex strips, where it would make contact whilst launching and landing. Eurofighter would launch of your ramp ok or the Hawk, but not the F14, I think it would leave the tailerons behind.
21 Dec 2020 17:55 #23875 by JonTappin
Replied by JonTappin on topic F14 developed a radio fault
John, have you considered a drop off 'dolly' for take off rather than a ramp?
Time to create page: 0.353 seconds
