Programming issue with Spextrum IX12
  • Wingman1962
13 Mar 2021 18:54 #24334 by Wingman1962
Programming issue with Spextrum IX12 was created by Wingman1962
Hello, Having some problems with my IX12 trying to program flight modes. I can get the flight mode to work perfectly on my Turbinator so as aileron trim can be applied to different flap settings and that's great. But I have tried to apply the same flight mode to the Viper and the F15 and they just wont work. Can not understand why the flight mode will work I one Jet but not the other two. Any suggestions would be most welcome.
  • Wingman1962
13 Mar 2021 20:58 #24335 by Wingman1962
Replied by Wingman1962 on topic Programming issue with Spextrum IX12
Thanks Dave B all sorted now:
13 Mar 2021 21:54 #24336 by DaveBright
Replied by DaveBright on topic Programming issue with Spextrum IX12
Very welcome
14 Mar 2021 11:42 - 14 Mar 2021 11:42 #24338 by Phil Ford
Replied by Phil Ford on topic Programming issue with Spextrum IX12
That was useful Dave :huh:
Last edit: 14 Mar 2021 11:42 by Phil Ford.
14 Mar 2021 12:35 - 14 Mar 2021 12:37 #24339 by DaveBright
Sorry, I messaged John to suggest looking for the ‘com’ / ‘fm’ options for flight mode trimming. One allowing trim to be common across all flight modes and one for individual trim settings per flight condition. This was likely to be in either the flight mode setup menu or in the trim menu itself. It was in the latter. In John’s example, he has the Turbinator set to ‘FM’ and wanted the same for the new models allowing him to trim differently at different flap settings when the flight mode switch is the same as the flap switch.
Last edit: 14 Mar 2021 12:37 by DaveBright.
The following user(s) said Thank You: Phil Ford, ruggerbloke
Time to create page: 0.263 seconds
