Which RX ??
03 Jun 2015 13:10 #4726 by Chris73
Which RX ?? was created by Chris73
Hi, I am just in the process of assembling an EPP Yak55, wingspan of approx 110cm
Do you recommend using a park flyer RX or full range??
Does anybody know the approx range of a JR park flyer rx??
Thanks
Chris
03 Jun 2015 16:32 #4728 by MikeSeale
Replied by MikeSeale on topic Which RX ??
Usually the only difference between a park flyer rx and a full range one is the number of antennae. Park flyer rx's typically have just one active antenna which means you increase the change of losing signal. Not usually a problem close in where you would lose and regain the signal without noticing...worse at range where you might lose signal for longer. Two antennae at 90 degrees reduces and/or eliminates the chance of losing the signal at distance.
I don't know the range of a JR park receiver, but the FrSky ones say 500m. This is fine for an EPP model which would rarely, if ever, get that far away. In short, yes, go ahead and use a park rx in the foamy.
03 Jun 2015 17:04 #4729 by JonTappin
Replied by JonTappin on topic Which RX ??
Chris
According to the specs the JR 611B park fly receiver has 300m range, plenty for a foamy, the cheaper 411B isn't stated but I would assume it would be similar.
I assume you want DMSS? If Spektrum, the cheapy HK orange ones seem to work fine for a foamy
03 Jun 2015 17:54 #4734 by Chris73
Replied by Chris73 on topic Which RX ??
Thanks for the answers, will order the DMSS 611b
Time to create page: 0.393 seconds
