Service/repair to O.S. 120 four stroke?
  • Simonosborne53
02 Jan 2017 13:25 #11400 by Simonosborne53
Service/repair to O.S. 120 four stroke? was created by Simonosborne53
I have acquired an almost new OS 120. Tried to start it but fuel leaking from pumped carburettor. Does anyone know where I can get it checked out/ repaired?
02 Jan 2017 15:38 #11401 by 4Pedalsfly
Replied by 4Pedalsfly on topic Service/repair to O.S. 120 four stroke?
Simon - I had a similar problem with the same motor about 10 years ago
& finished up sending it back to Ripmax who fixed it for me.
I cannot recall what they charged but I do not know who else services O.S engines.
What does the seller have to say ?
Hope you get it sorted.
The following user(s) said Thank You: Simonosborne53
  • Simonosborne53
02 Jan 2017 15:59 #11403 by Simonosborne53
Replied by Simonosborne53 on topic Service/repair to O.S. 120 four stroke?
Colin, I bought it some months ago and now needing the model finished off the build and tried to fire it up. Don't think the seller will be too interested now. I will take your advice ano get in touch with Ripmax.
02 Jan 2017 16:13 - 02 Jan 2017 16:14 #11404 by Phil Ford
Replied by Phil Ford on topic Service/repair to O.S. 120 four stroke?
May I suggest "Just Engines" they are based at Shaftesbury and very knowledgeable plus repair and carry spares for OS, ASP and NGH and others. Give them a ring to either sort it for you or supply parts for the job.
www.justengines.co.uk/
Last edit: 02 Jan 2017 16:14 by Phil Ford.
  • Simonosborne53
02 Jan 2017 17:11 #11407 by Simonosborne53
Many thanks Phil
02 Jan 2017 17:40 - 02 Jan 2017 17:41 #11409 by JonTappin
Replied by JonTappin on topic Service/repair to O.S. 120 four stroke?
Don't send it off yet Simon, it is a pumped engine so will drip fuel if not running as the pump will be constantly delivering fuel when ever it is turning over.
You might just need some help getting it running initially before assuming there is a problem with it. Can you bring it to Cashmoor so we can have a try there?
Last edit: 02 Jan 2017 17:41 by JonTappin.
  • Simonosborne53
02 Jan 2017 17:49 #11410 by Simonosborne53
Certainly can Jon, just let me know when you are going to be thereand I will bring the model foryoutohave a look at. I'm very grateful, thanks.
Time to create page: 0.368 seconds
