Removing solar film
  • simonbloke
13 Aug 2018 19:18 #17389 by simonbloke
Removing solar film was created by simonbloke
Hi
Any tips on a quick way to remove solar film from a balsa model.
I am revamping my super air
Any help appreciated
Simon:) :)
13 Aug 2018 19:38 - 13 Aug 2018 19:39 #17390 by JRI
Replied by JRI on topic Removing solar film
If it's an original super air then it won't be solarfilm - it will be chinafilm and will come off very easily with a little bit of heat from a hot air gun (for model film) or a hair drier or a clothes iron. Cellulose thinners will take of any remaining colur or glue.
Last edit: 13 Aug 2018 19:39 by JRI.
The following user(s) said Thank You: simonbloke
  • simonbloke
13 Aug 2018 20:08 #17391 by simonbloke
Replied by simonbloke on topic Removing solar film
It has been recovered , but I will persist with the heat gun
Ta
13 Aug 2018 21:45 #17392 by JonTappin
Replied by JonTappin on topic Removing solar film
Simon
Another method you could try is using sticky tape on any remaining patches, before using thinners. Rub it down well onto the areas where film is left, then tear off. It sometimes works well and sometimes doesn't, but worth a try
Time to create page: 0.426 seconds
