Excellent small drill selection
20 May 2019 10:05 #19582 by kevinross
Excellent small drill selection was created by kevinross
Just noticed this in the ALDI special buys. Excellent for achieving slop free servo arm to clevis clearance.
www.aldi.co.uk/workzone-hand-drill-set/p/011184281827700
This hand saw set also looks useful
www.aldi.co.uk/workzone-hand-saw-set/p/011184285075501
20 May 2019 10:48 #19583 by Phil Ford
Replied by Phil Ford on topic Excellent small drill selection
I am surprised you even considered Aldi tools Kevin considering your excellence in precision tooling or is it the Yorkshire save a penny element kicking in? :lol:
For slop free clevis to servo arm I warm up on the gas ring a spare piece of push rod the same dimensions as the clevis pin (usually 2mm) and push it through the arm. Perfect fit!
20 May 2019 11:30 #19584 by DavidTappin
Replied by DavidTappin on topic Excellent small drill selection
Kevin reported that he’d
Kevin, did you look closely at the picture of the drills? Either they used a mirror to make it look as if there were twice as many drills or otherwise it seems that half of them have a left hand spiral.
20 May 2019 11:59 - 20 May 2019 12:01 #19585 by JonTappin
Replied by JonTappin on topic Excellent small drill selection
DavidTappin wrote: Kevin reported that he’d
Good spot, did you see this review? What would be the point of reverse rotation drills??
Last edit: 20 May 2019 12:01 by JonTappin.
20 May 2019 12:31 #19586 by DavidTappin
Thanks for that Jon, no I didn’t see the review you attached.
The only answer I can think of to your question
is that you will find the point at the opposite end of the drill from the end by which you hold it in the drill chuck. This also applies to conventional right hand spiral drills.
20 May 2019 12:32 #19587 by Phil Ford
I spotted that review/comment too about left hand spirals. Maybe they were designed for people like me who are left-handed. :silly:
20 May 2019 14:47 #19588 by kevinross
Replied by kevinross on topic Excellent small drill selection
No i don't need them - Ive got mm. fraction, Number and letter drills of pretty much every combination EXCEPT no left hand helix so maybe i should add these to my collection. (no i didn't read the detail)
However talking to some new members, they don't have any drills as evidenced when assembling ARTF's so a means of gradually opening servo arm holes without spending fortune might be useful.
20 May 2019 15:30 #19589 by Chris73
Replied by Chris73 on topic Excellent small drill selection
Only tool you need, if it still doesnt fit you just need a bigger one :silly:
20 May 2019 15:32 #19590 by JonTappin
That's the same tool I use when I'm calling for Mitch at an IMAC comp
20 May 2019 20:34 - 20 May 2019 20:34 #19593 by kevinross
Called in at my local Aldi to stock up with left hand drills but the shelf was bare - an assistant said they all sold very quickly ( or were they recalled as faulty ! )
Last edit: 20 May 2019 20:34 by kevinross.
Time to create page: 0.706 seconds
