Repairing Broken Hinge on Foamee
  • 4Pedalsfly
01 Jul 2019 23:40 #19970 by 4Pedalsfly
Repairing Broken Hinge on Foamee was created by 4Pedalsfly
Looking for some advice on how to repair split " Foam " hinge on Hacker HotWing moulded in EPP foam.
I tried applying various tapes ( Selotape, masking, duct, GRP reinforced ) onto the top surface to form a hinge but none would stick, seems like there is some form of barrier on the surface.
Thanks
02 Jul 2019 00:10 #19971 by MikeSeale
Replied by MikeSeale on topic Repairing Broken Hinge on Foamee
Blenderm tape should stick.
Or make a hing by running a thin bead of UHU POR into the gap. Smear it with your finger and build it up in small stages if your gap is big. Dust it with talcum powder when you're done so that it loses its tackiness
02 Jul 2019 05:42 #19972 by Brian
Replied by Brian on topic Repairing Broken Hinge on Foamee
R/C Modellers Glue or Canopy Glue work well, as they are water based they clean up easily. I used it to fix the elevons on a foamie Raven wing.
02 Jul 2019 11:03 - 02 Jul 2019 11:04 #19976 by Phil Ford
Replied by Phil Ford on topic Repairing Broken Hinge on Foamee
3M Blenderm Surgical Tape. Defacto standard for foamies! Use it on all my foamies, flexible and hangs on to most surfaces and virtually transparent. Shame I forgot to apply some on my EFXRacer ailerons as Dave B will later prove at Ferndown....:lol:
Last edit: 02 Jul 2019 11:04 by Phil Ford.
  • 4Pedalsfly
02 Jul 2019 11:59 #19980 by 4Pedalsfly
Replied by 4Pedalsfly on topic Repairing Broken Hinge on Foamee
Thanks Guys - I'll get some Blenderm Surgical tape & give it a go & also beef up my Foamee" Beaver" hinges.
02 Jul 2019 13:29 #19984 by AlanF
Replied by AlanF on topic Repairing Broken Hinge on Foamee
4Pedalsfly wrote: Looking for some advice on how to repair split " Foam " hinge on Hacker HotWing moulded in EPP foam.
Thanks
My Extravaganza has had most of the aileron hinge repaired by running UHU POR along the hinge line. It has been subjected to some extreme abuse since and is still ok - it does go yellow over time tthough
