Bucker Jungmeister repair
02 Aug 2021 22:50 #24973 by kevinross
Bucker Jungmeister repair was created by kevinross
Following a dead stick landing in Pea field my Bucker Fuselage split. After stripping out the hardware and peeling back the covering it quickly became apparent that most of the failure was in the joint glue but i think calling it glue is too generous - maybe the chinese make it from snot or babies teardrops !
  • Brian Jackson
03 Aug 2021 07:41 #24974 by Brian Jackson
Replied by Brian Jackson on topic Bucker Jungmeister repair
There is a "good side" Kevin, at least you've a clean break to repair, not the usual torn mess of fibres that won't quite go together. Perhaps the wily Chinese designed the joint as a breakaway feature, but I don't think they'd be so kind.
07 Aug 2021 21:30 #24983 by kevinross
Replied by kevinross on topic Bucker Jungmeister repair
Clamped the parts with rope ties
07 Aug 2021 21:34 #24984 by kevinross
Looking further at the FG30 it appears the inlet valve mechanism has failed. The cam seems to have full lift but the push rod has dropped.
08 Aug 2021 09:11 #24985 by kevinross
The excessive valve clearance is due to inlet pushrod wear with swarfe in the tappet (cam follower) socket. Note the exhaust side benefits from valve stem blow past. This engine has at best had 1 1/2 hrs running !
Google reveals that inlet cam wear is common on Saito engines due to lack of lube in the design. So the sum up, my experience with expensive Saito engines is a disappointment compared to my cheap and nasty Chinese NGH which has run for nearly 3 years in my GP Stearman which has stopped once due to requiring a de-coke.
08 Aug 2021 16:55 #24987 by JRI
Replied by JRI on topic Bucker Jungmeister repair
I wonder if fitting nipples to the rocker covers and linking them together with silicone tube might allow some of the exhaust blow-by oil/vapour to reach the inlet rocker and pushrod Kevin?
08 Aug 2021 18:32 #24988 by kevinross
John Ireland wrote: I wonder if fitting nipples to the rocker covers and linking them together with silicone tube might allow some of the exhaust blow-by oil/vapour to reach the inlet rocker and pushrod Kevin?
Were on the same wavelength John, but that would be difficult with my installation, so my thoughts are
1. Silver solder a nipple on the pushrod tube for direct oil injection prior to flight
2. ditto both pushrod tubes and link those with silicone tube.
09 Aug 2021 09:10 #24989 by Phil Ford
Replied by Phil Ford on topic Bucker Jungmeister repair
Kevin Ross wrote: Silver solder a nipple on the pushrod tube for direct oil injection prior to flight
That seemed to work quite well in the early days of flight. ;) Why should it not work today?
14 Aug 2021 21:36 - 14 Aug 2021 21:39 #25007 by kevinross
having concluded that the only source of lube at the front end of the motor is via the exhaust valve, ALL the cylinder blow past lube is passing straight thru the rear vent so no oil is getting fwd of the main crank bearing onto the cams or the inlet tappet/ pushrod, ive carried out this mods. Pic 1 shows the groove in the exhaust tappet guide which is getting lube from the exhaust rocker cover and pushrod tube. Pic 2 shows the new groove ive made in the inlet tappet guide.Also ive installed a new vent nipple at the front, so the plan is to restrict the blow past lube from the crankcase rear vent and divert some to the front of the motor.
the pics are displayed in reverse order
Last edit: 14 Aug 2021 21:39 by kevinross.
21 Aug 2021 18:16 #25017 by kevinross
Finally ordered some matching Oracover for the repaired fuselage. A closer look reveals my compound curve covering skills have regressed.
Time to create page: 0.370 seconds
