Flyzone Sensei Trainer
16 Nov 2016 15:11 #10751 by DaveBright
Replied by DaveBright on topic Flyzone Sensei Trainer
MikeSeale wrote: Phil...Dave was just showing off that he knows the difference between "your" and "you're"
Just because I beat you to it Mike :)
16 Nov 2016 17:29 #10757 by DavidTappin
Replied by DavidTappin on topic Flyzone Sensei Trainer
Welcome to Pots and Kettles city.
  • FlyBuster18
18 Nov 2016 22:30 #10807 by FlyBuster18
Replied by FlyBuster18 on topic Flyzone Sensei Trainer
Hi All. Thank you for your comments. I will put a list of the items on here on sat morning.
Ernie
  • FlyBuster18
22 Nov 2016 13:54 #10851 by FlyBuster18
Here are the details of the Flyzone Sensie starter kit.
After watching and taking advice from club members I decided to buy a High Wing Trainer which is sold under four different names. This one is a “Sensie” of foam construction with a tricycle undercarriage. It comes RTF except for fitting the RX receiver. It also has a Giro module pre-wired. This my instructor Mike Seale advised me to take out of circuit because it may interfere with dual training, but may be useful when able to fly solo.
I have flown Sensie five times and the batteries last over 8 mins which takes them down to 33% capacity. These are an upgrade from the supplied 3s 2100mAh 20c. When fitted in the battery compartment in the nose this balances the plane well.
Specifications Wingspan: 58in (1475mm) Wing Area: 566 in2 (36.5 dm2)
Weight: 3.25 lb. (1470 g) Wing Loading: 13 oz/ft2 (40 g/dm2)
Length: 48 in (1220 mm) Radio: 6- channel (required)
Supplier: Inwood Model Supplies Items: all inc. vat.
Flyzone Sensie Trainer RTF £115.99
Spectrum DX6 (new 2016 version) inc. RX AR610 £174.90
Spectrum radio Lithium Battery & Charger £37.99
Dynamic 3s 2200 mAh 30c Li-po batteries x3 £36.00
Pro Peak Sigma ECO mains/12vdc charger £39.99
Li-po Battery checker £9.99
Aluminium case for Radio £22.99
Delivery FOC Total: £437.85
Two items I obtained from Sussex Model Centre :
Spectrum Neck Strap £14.49
6 Servo 100mm extensions £4.50
These were required to put the Giro back in circuit, when used, because I fitted the RX AR 610 receiver against the cockpit back wall, instead of the side wall.
As a newcomer to RC flying I decided to buy all main items from one supplier. The advantage was when I spoke to them I was assured that the Kit would all function together. It may have cost less if I had shopped around. Inwood, without any quibble, had to replace the first Sensie because in transit the tail end of the fuselage was broken.
I would recommend this model to anyone starting, even with my short experience. Although my instructor has put Sensie through a rigorous flight test with manoeuvres I can only dream of.
Happy Flying. Ernie Keene
23 Nov 2016 11:03 #10865 by 4Pedalsfly
Replied by 4Pedalsfly on topic Flyzone Sensei Trainer
Ernie - Thanks for posting the data, the wing loading is similar to my Wot 4+ foamee.
In the summer time you can fly high, find a thermal,shut the motor off, touch of up elevator
and float around like a glider - most relaxing.
  • FlyBuster18
23 Nov 2016 12:10 #10869 by FlyBuster18
Colin - Thank you, that sounds interesting and fun
23 Nov 2016 17:28 #10878 by MikeSeale
Replied by MikeSeale on topic Flyzone Sensei Trainer
Thanks for posting the list of items and prices you paid. It will be useful to know for other newcomers.
