Flyzone Sensei Trainer
8 years 10 months ago #10807 by
Replied by on topic Flyzone Sensei Trainer
Hi All. Thank you for your comments. I will put a list of the items on here on sat morning.
Ernie
8 years 10 months ago #10851 by
Here are the details of the Flyzone Sensie starter kit.
After watching and taking advice from club members I decided to buy a High Wing Trainer which is sold under four different names. This one is a “Sensie” of foam construction with a tricycle undercarriage. It comes RTF except for fitting the RX receiver. It also has a Giro module pre-wired. This my instructor Mike Seale advised me to take out of circuit because it may interfere with dual training, but may be useful when able to fly solo.
I have flown Sensie five times and the batteries last over 8 mins which takes them down to 33% capacity. These are an upgrade from the supplied 3s 2100mAh 20c. When fitted in the battery compartment in the nose this balances the plane well.
Specifications Wingspan: 58in (1475mm) Wing Area: 566 in2 (36.5 dm2)
Weight: 3.25 lb. (1470 g) Wing Loading: 13 oz/ft2 (40 g/dm2)
Length: 48 in (1220 mm) Radio: 6- channel (required)
Supplier: Inwood Model Supplies Items: all inc. vat.
Flyzone Sensie Trainer RTF £115.99
Spectrum DX6 (new 2016 version) inc. RX AR610 £174.90
Spectrum radio Lithium Battery & Charger £37.99
Dynamic 3s 2200 mAh 30c Li-po batteries x3 £36.00
Pro Peak Sigma ECO mains/12vdc charger £39.99
Li-po Battery checker £9.99
Aluminium case for Radio £22.99
Delivery FOC Total: £437.85
Two items I obtained from Sussex Model Centre :
Spectrum Neck Strap £14.49
6 Servo 100mm extensions £4.50
These were required to put the Giro back in circuit, when used, because I fitted the RX AR 610 receiver against the cockpit back wall, instead of the side wall.
As a newcomer to RC flying I decided to buy all main items from one supplier. The advantage was when I spoke to them I was assured that the Kit would all function together. It may have cost less if I had shopped around. Inwood, without any quibble, had to replace the first Sensie because in transit the tail end of the fuselage was broken.
I would recommend this model to anyone starting, even with my short experience. Although my instructor has put Sensie through a rigorous flight test with manoeuvres I can only dream of.
Happy Flying. Ernie Keene
8 years 10 months ago #10865 by 4Pedalsfly
Replied by 4Pedalsfly on topic Flyzone Sensei Trainer
Ernie - Thanks for posting the data, the wing loading is similar to my Wot 4+ foamee.
In the summer time you can fly high, find a thermal,shut the motor off, touch of up elevator
and float around like a glider - most relaxing.
8 years 10 months ago #10869 by
Colin - Thank you, that sounds interesting and fun
8 years 10 months ago #10878 by MikeSeale
Replied by MikeSeale on topic Flyzone Sensei Trainer
Thanks for posting the list of items and prices you paid. It will be useful to know for other newcomers.
Time to create page: 1.195 seconds
