Observer UAV Mods
8 years 3 months ago - 8 years 3 months ago #13261 by Phil Ford
Replied by Phil Ford on topic Observer UAV Mods
Wow! That's the little devil.:woohoo: 9 deg and 2 deg. Many thanks.
Yes Ron, I do have STL files but not sure which one is the master printer file. I have attached the ZIp file that I have. Note there maybe different files depending on motor rotation direction. Mine is CW.
Last edit: 8 years 3 months ago by Phil Ford.
8 years 3 months ago - 8 years 3 months ago #13278 by Phil Ford
After sending the files to Ron, thought no more about until Ron turned up at Cashmoor yesterday with this little object. Created on the late Frank Robinson's 3D printer. I believe the nozzle size was 0.5 mm. A finer surface would need a smaller nozzle but increases printing time and costs. Assuming the printer is able to make finer objects. Will have to fit the part and see how it goes.
8 years 2 months ago #13286 by Phil Ford
The part needed some smoothing down with fine sandpaper where it slots into the motor pod. Now fitted as seen in image.
Time to create page: 1.381 seconds
