Electronic Repair
8 years 4 weeks ago #13726 by
Replied by on topic Electronic Repair
Presumably the component burnt out, and presumably the component was serving some purpose, my guess is that it's a surface mount resister. Isn't bridging over the failed component with a blob of solder potentially going to lead to greater damage, especially as you don't know why the component failed in the first place?
8 years 4 weeks ago #13727 by Brian
Replied by Brian on topic Electronic Repair
Hi Colin, Chris has a point there. I zoomed in on your picture of the board, what I thought to be unsoldered contacts were all that was left of the original component. I wonder if the missing bit was a capacitor.? Perhaps you could find a circuit diagram on Google?
8 years 4 weeks ago #13728 by Phil Ford
Replied by Phil Ford on topic Electronic Repair
Looks to me like the master GND (negative) worked loose and as the full charging current also runs through here it got hot and burnt away the circuits print. I would suggest clean up area with a small fine wire brush and then clean area with meths/alcohol/jack daniels.;) If there is some print left i would insert a small post or use thick copper wire. Solder this is the best you can. If there is no print left then follow the trace in a bit. If it is wide enough drill a very small hole and then follow my suggestion previously about a post.
  • 4Pedalsfly
8 years 4 weeks ago #13731 by 4Pedalsfly
Replied by 4Pedalsfly on topic Electronic Repair
Thanks for everyone's comments, since I feel uncomfortable messing with something I don't understand
I'll show it to Mitch when I catch up with him at Cashmoor.
8 years 4 weeks ago #13734 by John Bannister
Replied by John Bannister on topic Electronic Repair
Colin I have a spare charger if you want to borrow it.
Regards John
  • 4Pedalsfly
8 years 4 weeks ago #13738 by 4Pedalsfly
joneb wrote: Colin I have a spare charger if you want to borrow it.
Regards John
John - Thanks for your kind offer, I'm now using what was my "spare" charger.
Time to create page: 0.985 seconds
