Extra 300 Electric Conversion
7 years 10 months ago #14591 by JonTappin
Replied by JonTappin on topic Extra 300 Electric Conversion
It'll be interesting to see how that compares to my EF 78" Extra Phil, must be a similar size?
7 years 10 months ago #14592 by Phil Ford
Replied by Phil Ford on topic Extra 300 Electric Conversion
JonTappin wrote: It'll be interesting to see how that compares to my EF 78" Extra Phil, must be a similar size?
Ah Yes. Your EF. What prop and cell count are you using?
7 years 10 months ago #14593 by JonTappin
PhilF51 wrote: ]
APC 20 x 10 and 10s 5000mah
7 years 10 months ago - 7 years 10 months ago #14595 by Phil Ford
I read up details on the EF Extra. Recommend an Xpwr 40cc Electric Motor on 10 cells with 22 inch Beech e-prop. Hacker would be A60 series. These motors use 8mm shafts - not sure about adaptor sizes though.
This afternoon before darkness fell, been trying to get the thing balanced (155mm back from leading edge or 20mm back from wing tube). I can get some slight nose down with those 2 x 6 cell packs when the batteries are just forward of the wing tube. Allowing for a 200 gram Lipo receiver pack behind the wing tube it "should" be about right. ;)
In case Jon's props are not for 10mm shafts I have located an Xoar Beech - E 21 x 10 at Probuild , so going to try that initially in conjunction with my clamp meter. Flying weight according to my wife's digital scales is 6.5kg
Could be a maiden soon.........:)
Last edit: 7 years 10 months ago by Phil Ford.
7 years 10 months ago #14599 by JonTappin
Mine has a Hacker Q60 Phil, but it's still an 8mm prop hole
7 years 10 months ago #14600 by DaveBright
Replied by DaveBright on topic Extra 300 Electric Conversion
Looks good Phil, looking forward to seeing it.
Time to create page: 1.713 seconds
