inflamed battery
11 Oct 2018 10:15 #18016 by MikeSeale
Replied by MikeSeale on topic inflamed battery
4Pedalsfly wrote: Jacob - HobbyKing used to ship their LiPo's at " Storage" Voltage which is 3.85 Volts per cell
but this changed awhile back
Are you sure, Colin? If they are not shipping batteries at storage voltage what are they now doing?
  • JacobWinfield12
11 Oct 2018 16:31 #18019 by JacobWinfield12
Replied by JacobWinfield12 on topic inflamed battery
one of my batterys are 100% charget the other is 23%
11 Oct 2018 16:43 - 11 Oct 2018 16:47 #18020 by Phil Ford
Replied by Phil Ford on topic inflamed battery
Is the battery at 100% full charge the one that is the problem? And you have not charged it then I would hazard a guess that it was a return. :unsure: If this is the case you are stuck unless you can pursue Hobbyking on the fact that it came like it. Never had an issue myself in 9 years with batteries from HK.
Sent message to phone.
Last edit: 11 Oct 2018 16:47 by Phil Ford.
  • JacobWinfield12
11 Oct 2018 16:56 #18022 by JacobWinfield12
the one that is the problem is 100% charged I have never charged it and checked the batterys one was 23 % and the other was 100% and the 100% one is the problem
11 Oct 2018 17:06 #18025 by Phil Ford
Thanks. Contact HK immediately with photo of battery. See what happens.
  • JacobWinfield12
11 Oct 2018 17:09 #18026 by JacobWinfield12
we have now
  • JacobWinfield12
15 Oct 2018 16:16 #18048 by JacobWinfield12
I have know delt with the battery and was a bit different then what was supposed to happen I kut the black wire then the red and the red made loads of sparks then a small fire on the red wire and I put it strate away in water know it is fine. it was a bit of a fright.
15 Oct 2018 18:51 - 15 Oct 2018 19:00 #18049 by Phil Ford
You were not trying to insert the 4mm bullets of the ESC leads into the XT90 battery socket were you? I did say I would swap/convert the plug ends for you to XT90
Last edit: 15 Oct 2018 19:00 by Phil Ford.
  • JacobWinfield12
15 Oct 2018 19:17 #18051 by JacobWinfield12
I wasn't I was just stabilising the battery and putting it in salt water
15 Oct 2018 19:21 #18052 by Phil Ford
Ah, I understand now. You were making it safe. Any joy with Hobbyking?
