inflamed battery
7 years 2 days ago - 7 years 2 days ago #18020 by Phil Ford
Replied by Phil Ford on topic inflamed battery
Is the battery at 100% full charge the one that is the problem? And you have not charged it then I would hazard a guess that it was a return. :unsure: If this is the case you are stuck unless you can pursue Hobbyking on the fact that it came like it. Never had an issue myself in 9 years with batteries from HK.
Sent message to phone.
Last edit: 7 years 2 days ago by Phil Ford.
7 years 2 days ago #18022 by
Replied by on topic inflamed battery
the one that is the problem is 100% charged I have never charged it and checked the batterys one was 23 % and the other was 100% and the 100% one is the problem
7 years 2 days ago #18025 by Phil Ford
Thanks. Contact HK immediately with photo of battery. See what happens.
7 years 2 days ago #18026 by
we have now
6 years 11 months ago #18048 by
I have know delt with the battery and was a bit different then what was supposed to happen I kut the black wire then the red and the red made loads of sparks then a small fire on the red wire and I put it strate away in water know it is fine. it was a bit of a fright.
6 years 11 months ago - 6 years 11 months ago #18049 by Phil Ford
You were not trying to insert the 4mm bullets of the ESC leads into the XT90 battery socket were you? I did say I would swap/convert the plug ends for you to XT90
Last edit: 6 years 11 months ago by Phil Ford.
